CRX Brake Bias on track
For those who track their CRXs, I have rear disks from an integra with the 4040 proportioning valve. The car has WAY too much rear brake when threshold braking. I was wondering what other peoples experiences were and what you are using.
I'm having trouble finding a 2040 proportioning valve, and they are discontinued from HONDA.
I would just go to a more aggresive pad up front. It would also be a good idea to recheck your rear camber just to make sure nothing slipped. Do you have stock rear drums lying around? If so you could just put them back on. They actually work pretty well, you just need to occasionally adjust them. Porterfield even makes a few compounds of performance shoes.
Also as a side note the 88 si calipers are smaller than the 89-81.
88 si caliper piston diameter - 49mm
89-91 si caliper piston diameter - 53mm
90civichbsi
19
Mar 4, 2014 07:04 PM
