header gaskets and bolts?
Noob q. I just bought a used DC header without the gasket or bolts. where could i get a gasket from and bolts that will fit and what kind of gasket do you guys use for the header?
You can probably re-use the metal exhaust manifold gasket on the head. If you want to get a new one, just get it from the dealership. As for the gasket that bolts to the exhaust, I'm not 100% sure of the size of the flange but most likely it's a 2.25" or 2.5" 3-bolt.
You can buy new bolts from any autoparts store (I got mine from Advance Auto). I can't remember the size; I think you'll need 3 M10x30mm bolts and 2 M10 nuts. Just bring yours in and match them up. The same goes for the bolts that connect to your cat-back exaust, I just used some grade 8 bolts from the hardware store with washers; I'd recommend getting as big of a bolt as possible that'll fit in the bolt holse.
r0cket247
Jan 15, 2004 04:21 PM
Isaac
Jan 6, 2002 10:23 AM
Isaac
Jan 5, 2002 01:11 AM
