Integra drive cycle
Old Mar 21, 2012 | 01:34 AM
kevinm1981's Avatar
Default Integra drive cycle
I took it to emissions after getting a new catalytic converter and o2 sensor and they said I need to take it to acura.. Do they charge to do this? Any info is appreciated.
Old Mar 21, 2012 | 06:53 AM
kevinm1981's Avatar
Default Re: Integra drive cycle
tttt
Old Mar 21, 2012 | 07:15 AM
hbcrazy88's Avatar
what are you asking? If Acura will install your 02 and cat..... if so yes and yes the will make you pay for it lol. not sure if thats what you were asking
Old Mar 21, 2012 | 07:17 AM
kevinm1981's Avatar
No. I mean will they charge to do the drive cycle?
Old Mar 21, 2012 | 07:39 AM
kyden's Avatar
yes they will charge you. just drive around for like 20-30 miles.
Old Mar 21, 2012 | 10:06 AM
B20ztek's Avatar
Stealerships will always charge you, they charge like $85 just to run your codes 0_0
Old Mar 21, 2012 | 10:25 AM
kevinm1981's Avatar
I drove it like 50+ miles and no check engine light. But when i went to emissions they said it wasnt ready for the test. One other thing is my odometer doesnt spin....
Old Mar 21, 2012 | 03:11 PM
kevinm1981's Avatar
Took it again and same thing happened. They are sending me somewhere else now. Damn i hope it works.
Old Mar 29, 2012 | 02:37 PM
kevinm1981's Avatar
Ok after weeks of trying i finally passed the ready to test test. then on the way to the emissions place the cel came on. I had to reset it and now i fail the not ready test again!!! this god damn car. What is wrong with it?
Old Mar 29, 2012 | 08:39 PM
el crapitan's Avatar
well you're going to throw a code for the speed sensor. instead of clearing the code, you should have checked what codes you were throwing. that way your readiness monitors wouldn't have to be reset
you're your own worst enemy there, bud
Old Mar 29, 2012 | 08:47 PM
kevinm1981's Avatar
ok checked at the auto store, its the o2 sensor, catalyst and evap..
Old Mar 30, 2012 | 03:39 AM
so those were the readiness monitors that haven't reset?
Old Mar 30, 2012 | 12:17 PM
kevinm1981's Avatar
Yeah, after days and days i finally passed the readiness ones. Then on the way to the other emissions place the cel came on.
Old Mar 30, 2012 | 08:36 PM
so are these the codes? or are they the unset readiness monitors?
Old Mar 30, 2012 | 08:37 PM
kevinm1981's Avatar
Those are the codes. So im running codes and running into readyness monitors too. This is hell. I just want to crash this POS ITR into a wall.
Old Mar 30, 2012 | 08:51 PM
ok. what are the exact codes? with the numbers please
and year of car
Old Mar 30, 2012 | 08:54 PM
kevinm1981's Avatar
The guy at autozone ran it with a obd scanner. He didnt give me the numbers if there were even any. I will do it tomrrow with the paper clip and post them here.
Old Mar 30, 2012 | 09:16 PM
Kennyjai's Avatar
heres how to get the o2 sensor ready
and the evap system
"A cold engine startup (ECT sensor signal more than 154ºF and IAT sensor signal more than 14ºF at startup) is required. Start the engine and allow it to run for 3-5 minutes, followed by an acceleration period to 50-60 mph at steady throttle.Temp has to be below 64-68 degrees, the highest I've been able to clear the Evap readiness is at 72 degrees."
I believe the cat and o2 monitors are the hardest to get ready
Old Sep 27, 2013 | 03:52 PM
Sarpedon's Avatar
Originally Posted by Kennyjai
and the evap system
Allow it to run for 3-5 minutes: Idle for 3-5 minutes? city drive for 3-5 minutes? Does it matter?
Old Sep 27, 2013 | 04:20 PM
B_Swapped93's Avatar
early 2012 thread bump ?
Old Sep 27, 2013 | 04:21 PM
Sarpedon's Avatar
Yup o/ I was searching for solutions to my current emissions problem :/
Old Sep 27, 2013 | 07:03 PM
m4xwellmurd3r's Avatar
Heres the problem, did you see him mention that it wont becone ready unless the temp is below 68 degrees? Yeah, try getting a car ready when a temp that low is required in the middle of summer in az. A guy had the same issue with his s2000. He had to keep his garage door closed, all vents taped up, door to the house open, and ac cranked to get the system to pass. I think he ducted the exhaust pipe out one of his vents, or opened the garage immediatly before starting it in the middle of the night.
And I believe its idle for 3-5 minutes so the ecu can perform its idle reset.
Old Sep 28, 2013 | 05:43 AM
Sarpedon's Avatar
That's what I've done so far. Ironically I have to drive to Phoenix this morning, so that should get plenty of mileage on the reset ECU.
Hondachef
Jul 7, 2013 04:00 PM
MugenDC4
Apr 12, 2008 10:34 AM
mfzbike
Feb 10, 2006 02:06 PM
blktyper2001
Sep 10, 2001 02:57 PM
blktyper2001
Sep 10, 2001 06:33 AM
