EG8 Air conditioning problem
Old Mar 20, 2012 | 11:22 PM
PassportBreh's Avatar
Default EG8 Air conditioning problem
My Air conditioning isnt really working, I can barely feel the cold air coming out. Can someone help me out thanks!
Old Mar 20, 2012 | 11:32 PM
jbpnoman's Avatar
Default Re: EG8 Air conditioning problem
Assuming your condenser pump is still working, when was the last time it was recharged? Considering the car is anywhere from 25 to 28 years old, it probably needs it.
Take it to a professional. Don't get the DIY kit. There is no way to prevent contaminants that'll fry your system.
Old Mar 20, 2012 | 11:34 PM
Yeah it's a 92, this might be a dumb question but How much does it normally go for?
Old Mar 20, 2012 | 11:53 PM
jbpnoman's Avatar
As with most work, it all depends on where you're located.
Old Mar 21, 2012 | 03:07 AM
angrysmileyface's Avatar
Beyond needing a recharge, have you checked to make sure your intake vent is not blocked with crud? IE does the heat blow with the same force as the cold?
Old Mar 21, 2012 | 05:35 AM
Former User's Avatar
A more clear description of the problem is needed.
Is this a vent air flow problem or an A/C problem?
Does the A/C work at all?
Is the heater possibly stuck on?
A stock 92 Civic uses old R12 rather than the more modern R134a refrigerant. Some shops can recharge R12 systems, though it's more expensive.
hoffmanp
Aug 13, 2014 08:59 PM
aust 97 coupe
Jan 3, 2009 05:21 AM
khurrum
Honda Civic (2001 - 2005)
Dec 22, 2008 09:16 PM
pippin65
Honda Civic (2006 - 2015)
17
May 10, 2008 06:33 PM
alscrx
10
Jan 3, 2008 06:57 PM
