Motor Mount's
Got a gsr with what it looks to be all OEM mounts, and am missing the driver side torque mount. My 3 bolt motor mount is shot to hell so i am thinking about replacing it with a hasport mount (individual), is that possible? also should i just buy the torque mount from autozone?
stiffer mounts do not compensate for not running torque mounts
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/ek-torque-mounts-question-2762534/
https://honda-tech.com/forums/showth...4#post39747484
DCLH is the part number and i would go with the 62a street urethane
please dont perpetuate this internet myth about the torque mounts
https://honda-tech.com/forums/showthread.php?t=2762534
have stock motor mounts.
Granted, the extra support doesnt hurt, but so its the same way with countless other things we do to our cars.
Oh? Thats funny because in the countless hondas ive ridden/driven without torque mounts, drove fine with no problems whatsoever for years. Half of them
Or you've driven weak *** **** cars.
Stock as stock can be man. i guess all cars are different. The ones I am referring to were a h22 swapped eg, ls swapped ek, Type-R ek, GSR ek, and a bunch more. If the mounts did fail, I can definitely see that happening, its all in the way you drive and how often you launch too.
Torque mounts are definitely a good idea with softer mounts and just for safety reasons. Although I run the stiffest hasport mounts in my integra without torque mounts with no problems.
did the stock mount break? no
did the block bracket pull out of the block? yes
would the same thing happen if running aftermarket mounts? yes
would torque mounts prevented some if not most of the damage? yes
this is not a debate over whether torque mounts are optional or not
THEY ARE NOT OPTIONAL
Internet myth people. Internet myth
something gets passed along/around long enough it gets taken as truth
if honda did not want torque mounts to be present or there was no need for them they would not have put them on the car in the first place
they are there for 2 reasons. 1st to keep the engine from torquing 2nd to keep the engine from entering the driver compartment in the even of an accident
You forgot reason 3, to keep engine from torquing more then Extension Change rod can compensate for.
Stop wasting your time, your not going to change the mind of "no-minds" untill it hits their pocketbook.
With the kind of thinking that goes on in the minds of those hackers, you wonder why there are doors on their cars, I mean the car would run fine, with out any problems, for years, right?
94
94
strictly.business
May 2, 2006 11:40 PM
