civic idle issue
Old Mar 20, 2012 | 01:41 PM
bmxking192's Avatar
Default civic idle issue
Hi guys, I have a 97 civic dx coupe with a manual transmission and a stock d16y7. Just over the last week or so when I clutch in to upshift or downshift my rpm's will stay where they were when the car was in gear. For example, if im cruising at 3k rpm and i clutch in to upshift to fifth the car will idle at 3k and not come down untill i tap the pedal a few times. Being that was the only solution to the problem I figured it needed a new TPS. So i replaced the sensor, set it up correctly and also cleaned the IAC valve. I still have the same issue. I am a full time mechanic so this stuff is not new to me I just was looking to get a second opinion on the situation maybe from someone who has experienced this, before I just throw a new IAC valve in the car. Any advice or suggestions would be greatly appreciated, thanks!
Old Mar 20, 2012 | 01:45 PM
Former User's Avatar
Default Re: civic idle issue
CEL codes?
Is the throttle body dirty and sticking open? Is the throttle cable too tight?
Old Mar 20, 2012 | 01:46 PM
Robin6's Avatar
clean your IACV.
Old Mar 20, 2012 | 01:54 PM
bmxking192's Avatar
no cel or dtc's. I cleaned the throttle body and the iac valve and im certain throttle is not sticking open and the cable is not too tight.
Gingerbread
Nov 29, 2017 05:12 PM
phelpsj2
Nov 3, 2011 02:35 PM
Hyaboosta
Mar 10, 2005 09:36 PM
turbod96ex
Jan 26, 2004 05:29 PM
plnoldrick
11
Jun 6, 2002 01:10 PM
