obd0-1 conversion i want to ad an engine light but how?
Old Mar 20, 2012 | 10:17 AM
civic46's Avatar
Default obd0-1 conversion i want to ad an engine light but how?
ok so i got a b16 swap in my crx its not a street car it has no dash or gauges just the bare wiring and a tin dash inside...so here is my question....
I got a obd0-1 converison harness with a chipped ecu i wanna hook a light up in the dash to act as my engine light and when something comes up it turns on and i then flick a toggle switch to make it blink....anyone got any info on how to go about this or where i can find the instructions on doing so? i cant be the first person to wanna do somethng like this lol
Old Mar 20, 2012 | 10:39 AM
Rtype16's Avatar
Default Re: obd0-1 conversion i want to ad an engine light but how?
Okay so I am not sure about your particular ECU you are running, but if the wiring is like the AEM 30-6040 which fits the 92-95 Integra/Civic/blah the Malfunction Indicator Lamp is on Pin A13. This is a low side grounded output. So you would need a light with 12V on one side and the other side goes to the ECU.
The Service Check Connector is on pin D4. However I am not sure if it is 12V or a grounded connection. My best guess would be a grounded connection. So you would need a switch to ground on one side and the other side going to pin D4
GMAN64
Apr 14, 2013 01:38 PM
davelarue
Jul 29, 2008 10:45 PM
eas156
Mar 17, 2006 12:43 PM
teler86
Nov 3, 2004 07:41 PM
86CRXSi
Jun 3, 2002 05:06 PM
