clutch not engaging !!!! need help asap
Old Mar 20, 2012 | 09:30 AM
Relentless Kaos's Avatar
Icon3 clutch not engaging !!!! need help asap
I need help I own a 1997 honda civic dx 5 speed
My clutch isn't fully engaging and I can't figure out why . I put a stage 3 clutch in
And after fixing my engine and everything I can't figure out why its not engaging .
I can shift it into a gear with the car on without touching the clutch and also when I do so my speedometer is reading speed !
I need help !! Please anything would be helpful right now
Old Mar 20, 2012 | 09:38 AM
grumblemarc's Avatar
The Grumpiest
Default Re: clutch not engaging !!!! need help asap
Stage 3 clutch doesn't really mean anything.
Are axles properly installed?
With the speedometer issue I'd have to suggest you double check your install. I haven't heard that one before.
Old Mar 20, 2012 | 10:29 AM
Former User's Avatar
This^
One of your axles is not fully inserted into the transmission differential.
Old Mar 21, 2012 | 09:56 AM
yes everything is properly installed and i cant figure out why in the hell its not working.....
its acting like its slipping but it shouldnt be.
it was all installed properly and the only thing i can think of is if something came loose while trying to put the engine back in.
Old Mar 21, 2012 | 10:03 AM
Dc4LsTeG's Avatar
EK9
what kind of clutch? Is it a new or resurfaced flywheel?
And recheck your axles
Old Mar 21, 2012 | 10:46 AM
pityocamptes's Avatar
Can you jack the front up (secure it), pull the cover plate and have a person push the clutch pedal in while you observe what is happening?
Old Mar 21, 2012 | 12:59 PM
fabioso's Avatar
have you bled the clutch? Also if one axle is not in all the way the car will not move. Are the shift rods moving?
Old Mar 21, 2012 | 01:05 PM
BiGMerK215's Avatar
haha axle definetly isnt in all the way, just had the same problem and i was certain they were in right even after rechecking until i saw trans fluid leaking, they can be sticking out like a 1/2 inch and diff wont spin.
Old Mar 26, 2012 | 09:38 AM
Icon3 Re: clutch not engaging !!!! need help asap
Hey guys I'm sorry I haven't posted back in a few days my internet shut off but thank you !!
The people who told me the drive shaft was correct it had slid out when swapping
The motor out . It was about a woping 1 1/2 inches out and all I did was tap it in and then it worked . So for allof you I wanna say thank you !!!! Everyone was a great help !!
Old Apr 6, 2013 | 10:14 PM
Mjc3po's Avatar
im having the same exact issue only I dropped the >tranny< (gigity) to see if there was an issue inside with some of the other gears and after taping together all the gears for removal ( as the manual suggest) I find nothing looking worn down other than normal wear on the syncro's I thought my axels were all the way in also but now I have to think I may have the wrong intermediate shaft
07 K20a3 Si
Oct 26, 2007 12:45 PM
The Specialist
Mar 24, 2004 07:03 PM
