OUT OF THE GAME PART OUT!
Just been to busy with school and work at the moment. Maybe when I get a chance I will start a new project. Serious buyers only. Don't waste my time nor yours if your not serious.
I started my 1995 Civic sedan build almost 2 years ago and was on the verge of finishing but have not had time to do so. Below will be a list of the build and parts for sale.
Mostly all parts are new, including pumps, bolts, nut all from oem honda.
I would like to sell the motor as a whole and the shell as a whole or together if possible.
Might be missing small things but should be most of it.
If I do not get what I want then I'll just keep it.
***I WANT TO PART THE MOTOR AND SHELL AT THE MOMENT***
***SORRY IF I HAD MISLED PEOPLE ON HERE***
***I WILL PART THINGS OUT IF THERE IS NO BUYER FOR BOTH***
PARTS LISTED BELOW IS WHAT I HAVE DONE TO THE ENGINE AND CAR.
**CAR IS NOT RUNNING**NEEDS A FEW MORE PARTS AND ITS GOOD TO GO
PLEASE LEAVE ALL NEGATIVE COMMENTS OUT AS I DO FOR YOU
PLEASE BUMP IF VIEWED AS I WILL DO THE SAME BACK
1995 Honda Civic LX 4dr (sedan)
-Chassis has 141xxx on the odometer when I put it away for storage
-3rd Owner of the vehicle if I remember correctly (will double check)
-Front core was pushed in at the bottom of the radiator support nothing major
-Rust bubbles on both sides
-Rust on the bottom wheel well size of 1 1/2 iches like a square on both sides (nothing major at the moment)
-Small little dents (was planing on getting a paint job after the build but I'm selling it now)
**BEFORE WE START, I WOULD LIKE TO STATE THE FOLLOWING BELOW WITH A PRICE SO PEOPLE KNOW WHAT I AM WANTING AS IN CASH PRICE FOR THE ENGINE OR SHELL** YES IT MAY SEE A LOT BUT THE TIME AND MONEY INTO IS MORE THAN REASONABLE**
**RLZ 1500.00** BARE
**BENSEN BLOCK 1500.00** BARE
**ITR TRANSMISSION 1300.00**
**TWM ITB 52MM 1200.00**
**SKUNK2 PACKAGE VALVETRAIN 1600.00**
-JUST THAT IN PARTS IS ABOUT 7000.00.
-PLEASE RESPECT MY PRICE AS IT HAS BEEN PUT TOGETHER PROFESSIONALLY AND RIGHT WITH THE BEST PARTS I COULD AFFORD. EVERYTHING IS ALMOST ALL NEW EVEN BOLTS.
EVERYTHING IS ALREADY PUT TOGETHER AND IN THE CAR WITH 0 MILES
Engine ?FIRM (HEAD,BLOCK,TRANS, MOUNTS, LINKAGE)(7k FIRM)
98 Integra GSR head from RLZ
-3 angle valve job
-CNC polished head
-Port and polished on both exhaust and intake side
-more information on RLZ's website
-Skunk2 Pro2 cam shafts
-SKunk2 Pro series valvetrain (retainers, flat valves, springs)
-Skunk2 Pro series cam gears
-Ferrea Bronze valve guides, seals, seats
-Hondata intake manifold gasket
-Anodized purple valve cover with 2 -10an fittings
-Felbro gasket still in box for valve cover
-TWM 52mm ITB (custom vacuum rail from ILLGARAGE)
-RC 330 or 440 (can't recall) injectors with clips
-Blox cam seal
-Toda timing belt (red)
-New distributor
-NGK wires
-RMF replica header
98 Integra GSR block (BENSEN SLEEVED to 84mm) From ht member
-Cleaned, decked, re-honed
-84mm sleeved bensen block
-Cometic 84mm head gasket
-ARP headstuds
-ARP main studs
-Eagle LS rods
-Eagle LS crank
-ACL rod, main, thrust bearings
-Manley 12.5:1 dome pistons 84mm
-Moroso oil pan
-B&R fitting in the back for catch can
-New alternator (autozone)
-New starter (autozone)
-OEM halfshaft (need bolts)
-Hasport motor mounts 62a street (polished)
-Moroso oil catch can with lines
-OEM itr oil pump (new)
-OEM itr water pump (new)
Transmission
-98 ITR LSD 4.7 final drive
-ACT 6puck unsprung clutch
-ACT 12lb flywheel
-ACT heavy duty pressure plate
-Hasport shift linkage with B&M race shifter
-Gator custom carbon axles for 500hp
-Mishimoto full radiator with 2 fans
-Mishimoto silicon radiator hoses
Suspension
-Ksports 36 adjustable (seen no more than 5k since storage)
-Ksports LCA
-Ksports front and rear control arms
-ASR (real) rear subframe
-ASR 24mm sway bar with links
-Beaks gold lower tie bar
-98 integra gsr front and rear disk brakes with new rotors (in box still)
-40/40 prop valve
-98 integra gsr new calipers all around (autozone)
-Eibach 26mm red front swaybar with links (not installed yet)
-Greddy SP2 catback (needs a polish)
-Benen front OG black tripod strut bar
Exterior/Interior/Shell (3k firm)
-Stanley sidemarkers
-Jdm corners
-Jdm center console
-Jdm ferio cluster
-Jdm ferio garnish
-Jdm climate control faceplate
-Jdm armrest with cupholder inside
-Jdm amber clock
-Jdm din with cover
-Jdm ITR non-srs steering wheel (horn not working yet)
-Oem sedan lip
-Oem mug flaps
-DEPO fogs
-Recaro gradation seats (SR3 style from WITZ) with WEDGE ENGINEERING brackets (new)
-DB8 ITR rear seats
-Blox or Skunk2 ****
-7in dual head unit
-12k HIDs Xenon
-Certifit bumper in black no cuts yet from fog but lip is installed
-Hondata s300 with benen cover
-Broadway mirror
-Harness bar (ht member 200 bucks)
I will post pictures up this week when I get a chance
-3 angle valve job
-CNC polished head
-Blox cam seal
-New distributor
-NGK wires
-RMF replica header
-ARP headstuds
-ARP main studs
-Eagle LS rods
-Eagle LS crank
-Moroso oil pan
Transmission
-ACT 12lb flywheel
Suspension
-Ksports LCA
-40/40 prop valve
-Jdm corners
-Jdm center console
-Jdm ferio cluster
-Jdm ferio garnish
-Jdm amber clock
-Jdm din with cover
-Oem sedan lip
-Oem mug flaps
-DEPO fogs
-DB8 ITR rear seats
-7in dual head unit
-12k HIDs Xenon
-Broadway mirror
Cool Cool Island Breezes. BOY-EE
Sorry. I'm a little confused as I am a slow reader/dangerous minority.
Are the parts themselves for sale? If so, I might be interested in that header if you wanna shoot me a price. Is the seat only singular? I would want to scoop that...but I'd need 2 of them.
Thanks.
Thanks.
I want part out the engine and shell first if possible guys. I am sorry if I misled some of you guys.
I will part out soon if nothing comes out or there is no buyer
