dizzy help for a6y8 what one?
Old Mar 20, 2012 | 07:36 AM
cardinalboy07's Avatar
Icon2 dizzy help for a6y8 what one?
ok i finished wiring up my ef from dpfi to mpfi.....the part im stuck at is what distributor to use i did research and ppl say use d15b7 dizzy..but dont line up... some say use y8 dizzy... heres my set up i got a obd1 dizzy from a 95 civic but doesnt line up..what do i do?
y8 head off 97 civic
y8 intake mani off 97 civic
chipped p06 ecu with jumper harness
a6 block 91 civic
odb2 injectors and clips (high inde)
Old Mar 20, 2012 | 08:07 AM
Default Re: dizzy help for a6y8 what one?
a lil help plzzz
Old Mar 20, 2012 | 08:15 AM
Eze209's Avatar
Had same issue when i did a mini swap wit a y8 head, i just used a smaller longer screw a put it on the top, since it was only one that lined up, and put a nut on te screw to hold it down...it worked for me and never moved
Old Mar 20, 2012 | 08:33 AM
cpl rampage's Avatar
all of the dizzy mounts are on the head, so you have a y8 head so use a y8 dizzy. If you have a OBDI engine harness you will need to repin the connectors if I remember correctly.
Old Mar 20, 2012 | 09:47 AM
Y8 is odb2 i cant use the dizzy from y8 im running odb1 ecu well thats what i read
Old Mar 20, 2012 | 10:00 AM
DCRB's Avatar
ugh whats with all this wrong information being passed around lately???
o/p you DO use the y8 distributor. obd1/2 has the same internals and sensor signals, they cross back and forth, so using the newer dizzy on your obd1 set up WILL work just fine.
Cpl rampage said it right
Old Mar 20, 2012 | 08:09 PM
MikeF's Avatar
d15b7 dizzy will work, I am currently running one on my 90 EX with a A6Y8 mini-me, obd1 converted on a p28. Y8 dizzy will not work on obd1, does not have crank sensor.
Old Mar 20, 2012 | 09:46 PM
DCRB's Avatar
idk where you get your info from but it is infact inside the dizzy for 97.
99-00 however does have the sensor located on the crank instead of in the dizzy.
o/p if you can get the b7 dizzy to work then use it, this guy has actually done this swap, i used a z6 head myself
Old Mar 21, 2012 | 05:27 AM
i figure the same thing isnt thats why i had to run the 2 extra wires from the ecu for the crank sensor? ima just use the b7 if you have same setup running fine i trust you...you think you can post a pic of it?
Old Mar 21, 2012 | 09:15 AM
fat honda kid's Avatar
i believe you can use the b7 dizzy just fine,
Old Mar 21, 2012 | 11:13 AM
v4lu3s's Avatar
RTFM
lots of bad information in here.
the sensor on the oil pump is called the ckf...crank fluctuation sensor...it appears on obd2 civics and integras. it does not appear on obd1 or obd0.
internally the obd1 and obd2 distributors on civics are the same, but have different plugs. the ckf is ONLY an issue if you are running an obd2 ecu.
R3X5150
14
May 14, 2013 01:12 AM
TravisCadello
14
Apr 12, 2009 10:37 AM
Super Chicken
Mar 7, 2005 06:15 PM
greddytunedhatch
Feb 7, 2005 04:47 PM
project dc2
Dec 19, 2002 10:42 PM
