abs light problem
Old Mar 19, 2012 | 06:39 AM
Dannyx321's Avatar
Default abs light problem
Ok so just a couple of days ago my abs light came on for my 1994 2dr gsr, I short the connector to figure out what code it maybe, but it doesn't blink or anything, just stays on bold and bright.
Never had this problem before and it use to work normally before
Is there anyway to figure out whyy it won't blink or reset?
Old Mar 19, 2012 | 08:46 AM
Drive 4 fun's Avatar
Default Re: abs light problem
How about a little description of your procedure. The first time I tried it, I did not make the connection because I did not get the paperclip in far enough to connect. Also, are you sure that you got the correct plug to short?
Old Mar 19, 2012 | 09:49 AM
Dannyx321's Avatar
Im taking a paper and putting in the blue plug located passenger side just above the kick panel for passenger, from one end to another. Im pretty sure its working too, bc when i short it, the cel comes on
Its just that when i do that the abs light doesn't blink at all, it just on not doing a thing
Old Mar 20, 2012 | 05:52 AM
Brady05's Avatar
I have a 97 GS-R and the same thing happens to me except it only comes on sometimes. But my SRS light came on a while ago and I have no clue why.
Old Mar 20, 2012 | 07:00 AM
Dogginator's Avatar
Daisy... Daisy...
Did the CEL light blink when the connector was jumpered?
Old Mar 20, 2012 | 09:47 AM
Dannyx321's Avatar
CEL light did not blink at all, it came up and just stayed on before i just pulled the paper clip, but the weirdest thing happen just now, i got out of class and turn it on just like normal and no more abs light?
The last thing i did was add brake fluid to both the clutch and brake resovir(i suck at spelling) the car and I did that last Friday?
ClarkS40
Mar 21, 2009 11:59 PM
prelude_93vtec
Apr 11, 2007 05:09 PM
Fliplm0de
May 9, 2006 08:08 PM
Corporation
Aug 21, 2005 08:55 PM
Joe
Jan 7, 2005 05:30 AM
