Does this look like a broken stud to you???
Old Mar 18, 2012 | 05:55 PM
JasinC19's Avatar
Default Does this look like a broken stud to you???
Took off the stock heat shield for what I thought was the first time ever and the bottom left stud/bolt (circled in red) seems to be missing. Does it look like it has been twisted off?
Any possibility a machine shop would be able to drill that out with the manifold off / head on the car and clean it up for me?
Thanks for advice
Old Mar 18, 2012 | 05:56 PM
ej1love's Avatar
Default Re: Does this look like a broken stud to you???
id say yes, from the 2nd pic
and with the mani off it can be fixed
Old Mar 18, 2012 | 06:05 PM
JasinC19's Avatar
Thanks... I'll swing by the machine shop tomorrow to see if they are up for it.
Old Mar 18, 2012 | 06:12 PM
ej1love's Avatar
GL
Old Mar 18, 2012 | 06:47 PM
jbpnoman's Avatar
You don't even have to take the manifold off to fix it. Just get one of those reverse drill bits and pull it out.
Old Mar 18, 2012 | 06:50 PM
dlstech's Avatar
Do you need to take the manifold off for some reason? If not, I would just leave it since it doesn't look like it's leaking or anything.
Old Mar 18, 2012 | 07:25 PM
JasinC19's Avatar
Replacing leaky oil pan gasket. Or I would just leave it. It's been ok for 12 years
Old Mar 18, 2012 | 11:30 PM
Hondasarekewl's Avatar
is it a pain to replace/fix oil pan gasket ones self? mine started leaking a while ago
Old Mar 19, 2012 | 01:59 AM
jbpnoman's Avatar
Oil pan gaskets are cake. Pull exhaust, pull flywheel cover, pull oil pan. Just make sure you don't lose any of those nuts/bolts. They're tiny.
Old Mar 19, 2012 | 08:59 AM
ej1love's Avatar
yea its not that bad at all
1999siguy
May 25, 2009 03:54 PM
StolenTeg
May 14, 2008 05:32 PM
No-Gi
Welding / Fabrication
29
Mar 14, 2007 07:29 PM
NuclearB18B
Jul 7, 2005 11:28 AM
TerribleOne
Nov 9, 2004 12:17 PM
