After piston soak, teg won't start
Old Mar 18, 2012 | 01:53 PM
safedriver's Avatar
Default After piston soak, teg won't start
Fixed!
Last night, I removed the spark plugs, from my 2000 LS and I poured 1 oz, seafoam into each cylinder.
I waited about 30 minutes and cranked it once, for 2 seconds.
I looked into each plug hole, with a flash light and saw no liquid, only dampness.
I installed my plugs and I started it right up, after 2 seconds of cranking.
I drove it 50 miles.
This morning, I repeated the process.
Before I put the plugs back in, I saw liquid in 3 of the 4 cylinders.
I put a towel over the valve cover and cranked it a couple of times, for 2 sec.
The towel got a little wet, but I couldn't see anymore liquid.
I put the plugs back and now it won't start.
It turns over and I checked for spark (there was no spark)
I bought new plugs.
It still won't start.
Any suggestions?
Old Mar 18, 2012 | 02:21 PM
TheRealTegger's Avatar
Default Re: After piston soak, teg won't start
You have killed your coil.
Old Mar 18, 2012 | 02:35 PM
racebum's Avatar
x2
Old Mar 18, 2012 | 02:43 PM
safedriver's Avatar
Once my helper comes back, I can check for spark directly out of my spark plug wire.
Until then, I will look for a primary resistance between .6 to .8 ohms and a secondary resistance between 12.8 and 19.2 K-ohms.
If these (Haynes, pg 5-1) values are good, can I check anything else, before I buy a coil and will a $22 dollar aftermarket coil work instead of an OEM 30510-pt2-006?
Update: the primary was .8 ohms but the secondary was 2.4 K-ohms. On the way to the store.
Replaced the coil and it's running, again.
Old Mar 18, 2012 | 10:40 PM
racebum's Avatar
if you ever check spark make sure all the wires are on the plugs, then, have 1 plug out of the hole while it's cranked and you watched the plug fire. do not put a wire to ground to check for spark, you'll kill your coil again
those ohm tests are also not always accurate i've seen bad coils test good
Old Mar 19, 2012 | 04:35 AM
That won't tell you a thing.
Pull the coil and look for a heat-spot, like the ones shown on this page:
http://www.tegger.com/hondafaq/badse...al-arcing.html
Old Mar 19, 2012 | 09:38 PM
grjr's Avatar
next time unplug the signal connectors at the distributor so that it doesn't fire while you are cranking the motor, better yet just remove the ECM fuse in the under hood fuse panel to disable everything while cranking.
Whatelseyouwant
Engine Management and Tuning
Apr 28, 2017 03:08 PM
Mindgamez
Jul 20, 2009 09:02 AM
wsteiger85
21
Feb 10, 2009 08:55 PM
streetsweaper
13
Oct 3, 2005 05:36 PM
hwnstyle21
Oct 28, 2002 08:00 PM
