What are good cams for high HP K boost
Old Mar 18, 2012 | 12:06 PM
a1320honda's Avatar
Default What are good cams for high HP K boost
Ive never built anythig K so im selling all my B stuff and gonna build a K. Looking for around 750-850hp. Going to be doing a K24 bottom end, CP's and Manleys, and using GT4294R with a 1.10A/R. I just have no idea where to even start looking for a good style cam for this.I wouldnt mind ditching the VTEC if its better. Sorry for the total noob sounding question.
Old Mar 18, 2012 | 02:26 PM
jdm knight's Avatar
Default Re: What are good cams for high HP K boost
Prayoonto racing cams!! My friend has those cams on his k series and they work great! It made good power
Old Mar 18, 2012 | 02:43 PM
13173's Avatar
Prayoonto Cams work well.
Got to watch which cams you use and how it is tuned. People have had problems with tearing up timing chains, tensioners, etc with certain cam manufacturers and cam profiles.
SP GARAGE's Avatar
Pmd
Old Mar 18, 2012 | 02:55 PM
YZFR6's Avatar
I would look into the Web cams, Prayoonto or BC cams if you got the money I hear that the Dragcartel one's are great as well. If you go with Prayoonto cams try his Stage 3, Stage 2 also makes great power from what I've seen.
Old Mar 18, 2012 | 04:21 PM
The Show Stopper's Avatar
^^^what he said
Old Mar 18, 2012 | 05:22 PM
bads2k's Avatar
prayoonto stg 2's here. made 60 more hp at same boost 25psi over stock cams. picked up a good bit of midrange torque too
Old Mar 18, 2012 | 05:48 PM
R@mon's Avatar
Contact Luke over at 4Piston , I'm sure he can get you the right cam that matches your setup.
Old Mar 19, 2012 | 05:43 PM
K20Ahondas's Avatar
thanks guys, cams are in stock for the time being. Let me know.
Old Mar 20, 2012 | 04:52 AM
D-Rob's Avatar
The Prayoonto's hands down are the nicest to tune cams, honestly. The cam angle maps make sense, I have never had a car tear up an OEM tensioner with them, and Norris' customer service is top notch.
Old Mar 20, 2012 | 05:06 AM
a1320honda's Avatar
I would prolly be using a "killer" cam. Im not worried t having VTEC or the variable timing.
Old Mar 20, 2012 | 10:17 AM
13173's Avatar
This is what I was referring to in my previous post. I have never heard anything bad about Prayoonto cams and it has been shown the make a nice amount of power over the stock cams in a turbo setup. Other cams I have heard of problems arising with them.
Old Mar 20, 2012 | 06:45 PM
K20Ahondas's Avatar
We do have killer versions, but variable timing (VTC) is a must. You will lose over 100hp if you don't use it in certain rpm ranges.
Old Mar 20, 2012 | 07:24 PM
izzles01's Avatar
^^^^ yup yup
Pr0j3ctxH@tchx90
Apr 20, 2007 03:38 AM
Yellow00TypeR
Feb 16, 2003 10:13 PM
MugenGTR
Aug 31, 2002 10:51 AM
