2003 RSX-S 6 spd transmission
Old Mar 18, 2012 | 07:23 AM
PSI GUY's Avatar
Default 2003 RSX-S 6 spd transmission
I swapped out a transmission for a customer a while ago, they opted for a low mileage unit replacement instead of an overhaul. The customer had issue with third gear grinding at high RPM and her father convinced her that she needed a new tranny. I made a deal with her to keep her old one in exchange for some labor cut off the job. I opened it up, and third gear synchro was beat and third gear teeth are dinged up a bit. A third gear set from the dealer would fix it up completely and I'd throw some mainshaft bearings in at the same time. Transmission had 120Kms on it, so 70K miles, and that was the only issue.
If anyone was interested, let me know, I can sell it as is, or repaired with the new parts installed. I am an Acura Technician so it will be done correctly. Also has a clean Vin tag on the case and can provide documentation on the origin of it if needed.
Looking for offers, I am located in Eastern Canada but have some contacts that go south quite often and I am willing to ship.
Old Mar 18, 2012 | 06:03 PM
Steven21's Avatar
Default Re: 2003 RSX-S 6 spd transmission
how much?
Old Mar 19, 2012 | 02:53 PM
PSI GUY's Avatar
I had it listed locally for $850 repaired, but no bites. Throw out some offers
CubbyChowder
Jun 1, 2010 04:44 PM
94_teggy_rs
Jan 1, 2008 09:20 PM
iBrandon
Aug 23, 2007 12:17 AM
HondaRcB
Nov 24, 2006 11:41 AM
godruler
Aug 13, 2006 10:15 AM
