93 Del Sol/B17 swap -- No prime on fuel pump!!?
Old Mar 18, 2012 | 06:17 AM
B17SolRide's Avatar
Default 93 Del Sol/B17 swap -- No prime on fuel pump!!?
Hey guys finally decided to make an account start a topic after searching through many threads and forums with no solution.
Here we go;
B17 in Del Sol, was running then changed the following; Skunk2 Intake mani, skunk2 fuel rail, Aem FPR, aem fuel filter, new ecu (went from p06 or p05 cant remember to a p30), and a different engine harness.
Problem- Fuel Pump Won't prime
What I tested and know- Replaced the main relay and it clicks once
-Fuel pump can be turned on by jumping connectors 5 and 7 on main relay connector
-Throwing what seems to be a check engine code 10 maybe 1?
-Did a K-Test on Ecu and got 5V at Map Sensor
-Tested ICM
-Replaced fuel pump (Airtex to walbro)
-Checked all fuses
-Checked ground on thermostat and cleaned.
Any help is greatly appreciated
Old Mar 18, 2012 | 07:29 AM
Former User's Avatar
Default Re: No prime on Del Sol fuel pump!!?
Does jumping 1-7 in main relay plug make the fuel pump run? If not, check whether the 15A hood ECU fuse is blown.
Old Mar 18, 2012 | 08:51 AM
B17SolRide's Avatar
Thanks for the quick response and yes the fuel pump does power on with 1 and 7 jumped.
Old Mar 18, 2012 | 09:06 AM
Is the G101 ground on the thermostat housing connected, clean, and tight?
If you unplug ECU connector A, turn the key to ON(II), and then ground terminal A7 or A8 in the unplugged connector, does the fuel pump run?
Old Mar 18, 2012 | 09:23 AM
B17SolRide's Avatar
I hooked the ground up to my battery ground and heard a click but no fuel pump.
I grounded both the connectors A7 ad A8 at separate times and they both kicked the fuel pump on
Old Mar 18, 2012 | 09:29 AM
Turn the key off and unplug ECU connectors A and B. Do terminals A26 and B2 in the connectors have continuity to body ground?
Now turn the key to ON(II). Do terminals A25 and B1 have battery voltage to body ground?
Old Mar 18, 2012 | 09:58 AM
B17SolRide's Avatar
I am getting very low amounts of voltage in A25 and B1 (about .3V) and very low resistance as well in A26 and B2 (about .2 ohms)
Old Mar 18, 2012 | 10:15 AM
B17SolRide's Avatar
Default Re: 93 Del Sol/B17 swap -- No prime on fuel pump!!?
I saw a spark when i first started testing then nothing after so I checked the fuses and noticed I blew out the 15A fuse in the engine bay for the ECU when testing the voltage.
Old Mar 18, 2012 | 12:09 PM
Problem solved?
Old Mar 18, 2012 | 02:07 PM
B17SolRide's Avatar
Problem solved?
The fuse actually blew when i did the first continuity test on A26
. Im not sure why this happened but this would mean that the three other tests were inaccurate as well.. should I try and test again ?
Old Mar 18, 2012 | 02:34 PM
Don't look back. Make sure you are probing the correct ECU connector terminals and try again.
http://www.phearable.net/tech/wiring...schematics.gif
Old Mar 19, 2012 | 07:23 AM
B17SolRide's Avatar
Okay I got it right this time. Here are my results;
A25 9.6V
B1 9V
Both B2 and A26 have continuity to ground
Old Mar 19, 2012 | 09:01 AM
A25 9.6V
B1 9V
These^ voltages are on the low side. What voltage do you read across the battery posts?
Old Mar 19, 2012 | 09:19 AM
B17SolRide's Avatar
About 11.4 Volts with the ignition switched off and about 11 and a steady decline with the ignition switched to II.
Old Mar 19, 2012 | 10:01 AM
Does the starter labor to crank the engine?
Old Mar 19, 2012 | 10:17 AM
B17SolRide's Avatar
Yes the starter does try to crank the engine although it doesn't sound very powerful
Old Mar 20, 2012 | 09:44 AM
B17SolRide's Avatar
I tried retrieving my check engine light code for this problem and the light continuously blinks every 5 seconds until I take the jumper wire out then it is solid. What would this indicate?
Old May 11, 2012 | 01:29 PM
7rrivera7's Avatar
I bet your problem is the ECU - I see this all the time...
Old May 12, 2012 | 06:34 AM
Old thread closed.
All Hondagirl
12
Aug 6, 2016 12:52 PM
86aw11
Dec 24, 2015 08:18 AM
almostjdmeg
Jul 21, 2008 05:19 AM
axionm1k
Jun 4, 2008 06:41 AM
civic2liters
Jun 1, 2008 08:11 PM
