Doing dpfi to mpfi then d16z6 swap
Old Mar 17, 2012 | 04:09 PM
osbunjosh's Avatar
Default Doing dpfi to mpfi then d16z6 swap
I just bought a 91 civic std.... yes a std lol. Motor and trans already have been pulled. I plan on making it mpfi and then swapping in a d16z6. I was just wondering if i did this :http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
Then bought this:http://www.ebay.com/itm/ECU-Conversi...#ht_2223wt_986
Would have work without any problems what so ever. I don't wanna do the dpfi to mpfi if the conversion harness would switch everything back... One of my buddy were talking about it and i just wanna make sure.
Old Mar 17, 2012 | 06:22 PM
osbunjosh's Avatar
Default Re: Doing dpfi to mpfi then d16z6 swap
bump
Old Mar 17, 2012 | 06:28 PM
crx_si-r's Avatar
you can use the ecu jumper ONLY after you convet to mpfi. if you dont convert then it wont work
Old Mar 17, 2012 | 08:27 PM
Nickeg9Ej1's Avatar
if yous dont mind spending the extra money boomslang.us sells and jumper harness going from obd0 dpfi to mpfi obd1 for like $150, makes everything super easy and nice if you need to track down problems
Old Mar 17, 2012 | 08:38 PM
crx_si-r's Avatar
I can make those as well. I also make full conversion harnesses all plug n play
Old Mar 17, 2012 | 09:41 PM
osbunjosh's Avatar
I can't find the dpfi to mpfi harness on that website. How much do you charge for a harness?
Old Mar 17, 2012 | 09:52 PM
crx_si-r's Avatar
DPFI to obd1 ecu jumper alone or full plug n play set up like this:
http://www.youtube.com/watch?v=puPiw...e_gdata_player
Old Mar 17, 2012 | 10:00 PM
osbunjosh's Avatar
The full plug and play harness. How much for that???
And at the end of the video you show obd1 ecu plugs and a conversation harness
Old Mar 17, 2012 | 10:23 PM
crx_si-r's Avatar
Yes. I wire up the harness just like an eg harness, but will plug into Ef chassis. And with the ecu jumper I do all the wiring that you would normally do for the mpfi conversion on the obd1 ecu plugs. A full plug n play conversion made with all new materials except for the sensor plugs.
Txt me for a price, I can't post prices on this thread
Old Mar 18, 2012 | 08:49 AM
osbunjosh's Avatar
I need a number lol
Old Mar 18, 2012 | 09:36 AM
crx_si-r's Avatar
916-541-5266
Old Mar 18, 2012 | 09:47 AM
91DxVTEC's Avatar
Trust crx_si-r to do harness! Literally got mine a week ago and is working on my jumper harness for ecu right now. Lol His work is incredible! Everything lined up perfect. It was like better than stock. Go with him you wont be sorry!
And thanks again for everthing crx_si-r!
Old Mar 18, 2012 | 10:00 AM
91DxVTEC's Avatar
Going from 91 civic dx to 92-95 jdm d15b vtec
Old Mar 18, 2012 | 06:36 PM
osbunjosh's Avatar
I still need to wire in a resistor box to run a d16z6 in my ef right?
Old Mar 18, 2012 | 09:09 PM
crx_si-r's Avatar
It all depends on which injectors you use
Old Mar 19, 2012 | 08:32 AM
tle05's Avatar
Originally Posted by crx_si-r
916-541-5266
I sent you a txt.
dudesmccool
Jan 7, 2016 01:19 PM
RuneRavenX
10
Feb 27, 2013 07:33 PM
chafetzk
Aug 10, 2010 08:32 AM
rsdracing
Jul 19, 2006 01:32 PM
mamaboy
19
Jan 23, 2004 06:43 AM
