99 EM1 horn stopped working (solved)
Old Mar 17, 2012 | 03:38 PM
HondaSunshine's Avatar
Default 99 EM1 horn stopped working (solved)
coming back home on high i kinda heard it die down when using it. after clicking i hear a clicking sound in the fusebox under wheel. checked fuses everything good? dont get it?
Old Mar 17, 2012 | 03:40 PM
grumblemarc's Avatar
The Grumpiest
Default Re: horn stopped working
What car? Please list all car details. Horns run off of relays. Check the ones for the horn.
Old Mar 17, 2012 | 03:41 PM
99 civic si em1
wheres the relay located? i thought off fuses
Old Mar 17, 2012 | 03:43 PM
The Grumpiest
Get a manual. Maybe even try looking it up on Google. Jint. It's probably right where you hear the clicking noise coming from. Get on your back and listen for it.
Old Mar 17, 2012 | 05:10 PM
HondaPartsHero's Avatar
Technical Hero
Could be a couple of things. Could be your steering wheel buttons, the fuse, the relay or the horn itself. The best first thing to do is to take check the underhood fuse:
Next see if your relay is working under the dash: (highlighted 424)
If your fuse and relay is good take a voltmeter and put it on the horn connectors. One side should be ground and one should be 12V. If you have 12V coming to the horns more than likely your horn is bad, or check your connector and make sure it has good connection. If it has 12V and ground your horn is bad.
Old Mar 18, 2012 | 08:13 AM
Gabe Cusmir's Avatar
thanks HondaPartsHero very clear it was the horn it died.
LiL JoN
10
Jun 22, 2010 09:22 PM
taguchi08
Dec 9, 2008 08:20 AM
Mr. Em1
Feb 5, 2008 12:41 PM
frizzo
11
Jul 22, 2007 10:02 PM
hans stoner
Oct 2, 2006 06:11 AM
