98 Civic Coupe oil plug stuck
Old Mar 17, 2012 | 01:27 PM
Bakado's Avatar
Default 98 Civic Coupe oil plug stuck
I'm trying to do an oil change on my 98 ej8 and the plug is stuck I can't get it off. Any helpful tips for loosening it?
Old Mar 17, 2012 | 01:32 PM
BrayzieEF9's Avatar
Default Re: 98 Civic Coupe oil plug stuck
What do you mean, by it's "stuck"? is the plug stripped or just really tight?
If stripped, try some channel locks.
If really tight, use a breaker bar.
Old Mar 17, 2012 | 01:36 PM
Bakado's Avatar
Just really tight. The last person to do the oil on it was my buddy who is a mech at honda he would have told me if it was stripped or whatnot. Yay another tool.
Old Mar 17, 2012 | 02:11 PM
vitamin_c95's Avatar
leverage....what kind of tools you using? Try using your feet to push on it
Old Mar 17, 2012 | 02:21 PM
jerimrc's Avatar
how about letting the car run for like 2 mins and turning it off. i usually do that and helps loosen the drain plug and the oil filter. maybe its the change in temp? dunno..
Old Mar 17, 2012 | 03:16 PM
Bakado's Avatar
Yea I though running the car would heat up the metal. I'm using a ratchet with a 4" handle. The only other thing I have is a old school torque wrench with no adapters that fit it, unfortunately the closest auto/tool store around me is 15 minutes away.
I have the car up on jack stands I don't know if idling it while it's up is a good idea... But to put it up I have to use the jack that came with it till the floor jack I have can fit under then put the jack stand underneath and visa versa to remove it. If it's not safe I'll do it the long way, better safe than sorry. I have the e-brake on and 2 2x4s behind the rear wheels.
Old Mar 17, 2012 | 04:37 PM
Bakado's Avatar
Thanks guys, I used a mixture of running the engine a little and a rubber mallet. Came off nice and smooth.
Old Mar 17, 2012 | 10:23 PM
jerimrc's Avatar
good job!
Old Mar 18, 2012 | 02:54 AM
redm3turbo's Avatar
dont put it on so tight next time
and
buy a real ratchet.
Old Mar 18, 2012 | 05:42 AM
furious94ls's Avatar
Old Mar 18, 2012 | 06:00 AM
thank you furious....I didnt know how to explain that. Also, for us with experience, you can use your hand as a mallet
Old Mar 18, 2012 | 06:06 AM
Red_Army's Avatar
tell your honda mech friend to learn the torque specs of an oil drain plug. should never be on so tight.
Old Mar 18, 2012 | 06:22 AM
Former User's Avatar
D16Y7 & B16a2 = 33 ft-lbs
D16Y8 = 29 ft-lbs
Slipjack
15
May 15, 2005 02:02 PM
MilanoRex
23
Feb 8, 2004 05:34 PM
ee-gsr
Jul 13, 2002 01:48 PM
00b18b
Feb 20, 2002 02:55 PM
