93 civic VX....doing swap and cant find MAP SENSOR???
Old Oct 10, 2002 | 05:26 PM
HybridCoupe's Avatar
Default 93 civic VX....doing swap and cant find MAP SENSOR???
doing a swap in 93 VX and cant find map sensor....on the firewall there is a white circular thinngy and a square 2 wire plug but no map sensor....
Old Oct 10, 2002 | 05:28 PM
liam821's Avatar
25 Year Member
Default Re: 93 civic VX....doing swap and cant find MAP SENSOR??? (HybridCoupe)
On the 92+ civics/teg they are on the top of the throttle body. which a three pin plug.
liam
Old Oct 10, 2002 | 05:30 PM
Default Re: 93 civic VX....doing swap and cant find MAP SENSOR??? (liam821)
usually when you do a swap in 92-95 civic you plug the map sesor that is on the fire wall into the map that is on the top of throttle bodie of your swap motor
Old Oct 11, 2002 | 02:18 AM
Mista Bone's Avatar
D Tranny Guru
incorrect there liam821.............
92-93 CX/DX/VX/LX had a firewall mounted MAP sensor, the EX/Si had a throttle body mounted MAP sensor.
Old Oct 11, 2002 | 04:26 AM
buzlink's Avatar
Default Re: 93 civic VX....doing swap and cant find MAP SENSOR??? (Mista Bone)
I was going to say what the mug.
Yup mines on the firewall.
Grey looking thing I believe
Off to middle left or so.
[Modified by buzlink, 7:27 AM 10/11/2002]
Old Oct 11, 2002 | 07:27 AM
nsxmatt's Avatar
Actually all VX's had a TB mounted MAP also.
Old Oct 11, 2002 | 07:39 AM
ill phil's Avatar
Default Re: 93 civic VX....doing swap and cant find MAP SENSOR??? (nsxmatt)
I also believe it was the same for 92-93 CX's and VX's. TB mounted- at least for 93 CX/VX.
[Modified by ill phil, 10:41 AM 10/11/2002]
Old Oct 11, 2002 | 07:45 AM
DOHCtorTHRUST's Avatar
Default Re: 93 civic VX....doing swap and cant find MAP SENSOR??? (ill phil)
"92-93 CX/DX/VX/LX had a firewall mounted MAP sensor, the EX/Si had a throttle body mounted MAP sensor. "
_______
i have a cx, and my map was on the TB......
i think only dx hatches came with the map on the firewall
[Modified by DOHCtorTHRUST, 4:46 PM 10/11/2002]
Old Oct 11, 2002 | 12:16 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: 93 civic VX....doing swap and cant find MAP SENSOR??? (DOHCtorTHRUST)
well, I guess the 92-93 DX/LX were the special ones. Doesn't really matter, they work the same.
MMMGIRL
Oct 19, 2014 02:44 PM
Munkeyd00d
Oct 3, 2011 07:20 PM
SVOboy
Mar 26, 2006 11:48 AM
HybridCoupe
Oct 10, 2002 09:20 PM
