idle issues/driving issues
Old Mar 16, 2012 | 06:38 PM
parki59's Avatar
Default idle issues/driving issues
Ok so bare with me here but I'm having issues
D16y7 w/ skunk2 intake manifold
I swapped in a GSR TB and relocated the IACV to the back of the manifold and converted too 2 wire. Swapped the MAP and TPS to the GSR TB. And added 240cc injectors
Had a P06 with basemap that makes it run like crap(not drive able) and because of the 2wire conversion I can't run my stock Y7 ecu. I am currently running aY8 ecu just to get me around.
While I get around my idle bounces from 700-900rpm. Also randomly when I left off the throttle the rev doesn't move and when I get on the gas again the car jerks and continues to go. Also randomly under load the car would start chugging and poping at 1500rpm
I cleaned out the IACV and TB really well before installing them. On the PO6 I don't get any codes. But on the Y8 I get a CEL(I'm assuming its cause lack of VTEC) I haven't checked with an OBD2 reader due to not owning one.
Any suggestion?
Old Mar 16, 2012 | 11:26 PM
parki59's Avatar
Default Re: idle issues/driving issues
also, the fitv is still on the TB but capped, and the hose barb at the top(for charcol canister i think) and the barb on the bottom are not running to anything....
Old Mar 17, 2012 | 04:39 AM
grumblemarc's Avatar
The Grumpiest
Any suggestion?
What are you asking for suggestions for? You already KNOW what the issue is. Get a better basemap to compensate for that intake and bigger injectors. Phearable burns basemaps to chips so good you almost don't have to take it to get tuned. $35.
Old Mar 18, 2012 | 01:21 AM
parki59's Avatar
im in canada phearable was uncertain how the elivation would effect their tune, but thanks anyways. I played around with some stuff today(map sensor and tps) and the only problem that seems to remain is a high reving cold start and when even when the car is warm the rev stays and 1500-2000rpm until the car is in motion, early this morning(4am, dont ask why) i started it and it stayed at 4k. while i drove home everytime i clutched in it jumped to 3k.
after playing with the MAP and TPS i was able to run the P06 with a basemap but now just cold idle seems to be the issue.
Even though the FITV has none of the hoses hooked up i am going to try blocking it with a gasket.
Old Mar 19, 2012 | 02:47 PM
parki59's Avatar
So turns out you must run a block plate/block gasket between the FITV and TB if you arent running the coolant to it. Idle is close to normal but I found out the chip for my base map is faulty and the tuner cannot erase the chip to reload the new base map. He will have a new basemap/chip for me tomorrow
Leviatard
18
Oct 30, 2014 09:28 AM
triple5soul4165
Feb 20, 2009 03:20 PM
mortificationrock
Jul 9, 2007 07:54 PM
97ekcoupe
Mar 18, 2007 09:32 AM
