Rotor set screw ? if gone will it make car run crappy ??!
Old Mar 16, 2012 | 03:47 PM
jkeith's Avatar
Icon3 Rotor set screw ? if gone will it make car run crappy ??!
I am missing my rotor set screw I just discovered after replacing cap and rotor and then having hesitation issues. Will a missing set screw cause this ??
Please help ?? In a bind! Thanks guys !
Old Mar 16, 2012 | 03:48 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Rotor set screw ? if gone will it make car run crappy ??!
It did on my Prelude when the screw came loose.
Old Mar 16, 2012 | 03:49 PM
motegicivic's Avatar
Well you do not want the rotor loose in anyway. You might be able to order one from honda dealer prob under a buck. How old is the cap and rotor, maybe time to replace anyway.
Side note some cheap aftermarket rotors do not use a screw they are pressure fits.
Old Mar 16, 2012 | 06:05 PM
94EG8's Avatar
Seagull Management
Yep, sure will, like the guy above me said some aftermarket rotors don't have a hole for the screw, but otherwise you need one.
Old Mar 16, 2012 | 06:09 PM
solis153's Avatar
yes your car will run crappy!
Old Mar 16, 2012 | 06:57 PM
deving916's Avatar
mine were stripped, the shop said I didn't need them, but i got them from honda for like $2
David_S
10
Nov 17, 2014 08:06 PM
jdmvtecej2
Apr 8, 2008 06:53 PM
thaseint
Suspension & Brakes
Feb 6, 2007 06:38 PM
superhatchbackbros
May 19, 2005 04:54 PM
turbo01LS
Feb 19, 2005 08:41 PM
