95 Civic runs for a couple minutes then just dies
Ok so i went through hell doing my first engine swap on this car and it ran great for a couple months, but now it's doing this thing where I'll start it up and It'll run for a couple minutes then just die. I've checked the fuel system and the alternator they are both good so if anyone has any good suggestions for what to check next let me know Thanks for taking the time to read this post.
CEL= check engine light?
Yellow light on dash. Itll appear for a second normally when you start car, if you have one itll stay lit. If you dont see it appear normally at startup, then theres other problems.
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
No. Is the CEL even working? Hard to believe you have such an issue and no CEL goes off. And what do you mean you "checked" the fuel system?
might be dying after car swithched off fast idle check the IAC valve will be directly on the back of the inlet manifold,
once you take it of check the gauzed hole in it to see if it is gummed up if so carb cleaner should take care of it and allow you to check if it causing the problem.
Yeah CEL works it turns on when i put the key in on position like it should then turns off as soon as i start it. and PeteABread ill check that out.
Well it was definitley clogged so i cleaned it out and then i drove it around for a little bit but now i went to take it out again and i got maybe a quarter mile away from my house and it died on me again wouldn't start no check engine light or anything would it be water in the gas that could be clogging this? Also when it was running it had a really low idle it was just above the second line after zero on the tach so around 200 maybe
soo my cars still doing the same thing and still no cel or anything could a faulty computer cause this? and how would you check that out?
hmm not really sure what it could be but sounds like a bad main relay if ur luckie its a easy fix assuming its cheap sence u just ahve to pop it out n put new in
not that im saying to just buy it n hope thats the issue hopefully u can pocket it from a junkyard <.<;
(should be under the dash)
100$ its an ignition switch,
ive seen two go out in the same day, same driveway before!
both 95's
1 accord 1 civic
www.tegger.com/hondafaq/startproblems.html
www.tegger.com/hondafaq/mainrelay.html
both 95's
1 accord 1 civic
Alright well recently i took the top bolt off of the fuel filter to check and see if it was getting fuel and after i did that it started up and ran fine i drove it probably 5 miles with no problems at all came back out a couple hours later and it started up then immediately died so would that be the relay or the ignition switch?
NorCal_ej1
Jan 23, 2014 01:28 AM
ever'sneighborhood
Nov 13, 2012 08:41 PM
Daysleeper15
11
Aug 2, 2004 10:27 AM
