94 Civic EX - bad gas mileage, engine stalls, misfires, shoots water out cylinder
Old Mar 16, 2012 | 02:45 PM
baileygirl's Avatar
Icon3 94 Civic EX - bad gas mileage, engine stalls, misfires, shoots water out cylinder
Info: red 1994 honda civic EX VETCH
168000 miles
5 Speed
Last oil change was about a month ago.
as of today 3/16/2012 I put a fuel filter and spark plugs in.
Problem: At the beginning of this week my car has been drinking ALOT of gas. So i changed the fuel filter today along with spark plugs. Also when driving as in slowing down to pull into a parking space or making a turn somewhere or even at a redlight my car would cut off. Not cut off like stall or die because my radio and such was still on it just wasnt running. But since changing the plugs my rpms have risen since they would go really low when slowing down like below 600.
Anywho, its has bad vibration in the steeringwheel to where my whole car shakes and its very noticeable. But since the fuel filter and plugs were changed it seems to be riding better BUT still vibrates at idle. On top of that my boyfriend said one of my cylinders seems to be misfiring but i dont know. Its not acting out just the vibration. Ive read things about the distributor coil, cap, and button. Any input would be greatly appreciated. Hopefully I havent confused you all.
TIA
Old Mar 16, 2012 | 03:19 PM
Alexpro's Avatar
Default Re: Problem!! 1994 Honda Civic EX
Sounds like your BF right, I have a strong feeling your car running on 3 cylinders on low RPM... Have some one look at it,someone who knows what hes looking for... its hard to say without diagnostics... Could be Fuel filter, Distributor coil, Distributor cap, Vacuum issue, MAF sensor, TPS sensor... I can go on but no point...
Old Mar 17, 2012 | 06:16 PM
baileygirl's Avatar
I replaced the fuel filter and the distributor cap button and wires. Its all working its all firing but now its shooting water out of the cylinder.
Old Mar 18, 2012 | 07:17 AM
Former User's Avatar
Default Re: 94 Civic EX - bad gas mileage, engine stalls, misfires, shoots water out cylinder
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Compression test the cylinders. The head gasket may be blown.
Old Mar 18, 2012 | 08:14 AM
motegicivic's Avatar
Water like coolant? How do you know it is shooting water? are you sure it is the cylinder, how could you see that since that is in the block?
Old Mar 18, 2012 | 09:13 AM
dlstech's Avatar
She's saying out of the cylinder, not in. That would be a really bad head gasket leak. Can you take a picture of where it's shooting from?
Old Mar 18, 2012 | 09:39 AM
baileygirl's Avatar
Yes ill upload one.
Old Mar 18, 2012 | 09:42 AM
Hidenplanvew's Avatar
how can you tell if its shooting water out? does the exhaust smell sweet? Some water out of the tail pipe is normal.
Old Mar 18, 2012 | 09:49 AM
baileygirl's Avatar
Because when we took the plug out it shot water like 4 feet out of the cylinder. No sweet smell. My car never overheated nor smoked.
Old Mar 18, 2012 | 09:53 AM
baileygirl's Avatar
[IMG][/IMG]
Old Mar 18, 2012 | 01:09 PM
ehrkeith's Avatar
I just gotta say something is probably majorly wrong if anything (gas, water, oil, brake fluid whatever) is shooting out 4 feet in the air when you remove the spark plug wire. Could you take a video lol
EDIT: it looks like your engine bay is covered in old brown radiator fluid squirting from some where, I had an explorer with a leak in a hose and my whole engine bay was that color of rusty brown.
Old Mar 18, 2012 | 01:49 PM
baileygirl's Avatar
idk what an engine bay is.. but i live on a dirt road so everything looks rusty. I know i have an oil leak. Ive had it since I bought the car but its near the soleniod?. And we did a compression test and is 180. So we dont believe its a compression problem. It only shot out the water once now if you have the wire up you can see it fill with water but we do not know where the water is going because my oil isnt milky. This is the most frustrating thing ever..
Old Mar 18, 2012 | 01:54 PM
baileygirl's Avatar
and to top it all off..we have been trying to figure it out all day without pulling the head off unless we know for a fact it is the head, the cylinder next to it is now flooding with water. So my car is now running off of 2 cylinders. wtf
Old Mar 18, 2012 | 03:08 PM
grumblemarc's Avatar
The Grumpiest
You're running your car like this? Have you even done a leakdown test? Probably too late for any tests. Engine is probably shot. I wonder how it hasn't hydro-locked yet.
Old Mar 18, 2012 | 03:39 PM
baileygirl's Avatar
No i havent actually driven my car since it cut off on me last week....
Old Mar 18, 2012 | 03:41 PM
The Grumpiest
Old Mar 18, 2012 | 03:43 PM
JDM_teh_WIN!!'s Avatar
They say 1 out of 10 civics is a squirter.
baileygirl's Avatar
We checked the cylinders they didnt show any compression being lost. My boyfriend is tearing the car down now and has the head off and its not the head gasket
Old Mar 18, 2012 | 03:44 PM
baileygirl's Avatar
Well this squirter isnt running.
Old Mar 18, 2012 | 03:50 PM
The Grumpiest
You checked them how? Doesn't really matter since you're disassembling the engine. My money is on a cracked block.
Old Mar 18, 2012 | 03:54 PM
Cracked cylinder wall? Thats pretty much the only way coolant can get into the cylinder if you say it isn't the head gasket.
Old Mar 18, 2012 | 03:57 PM
baileygirl's Avatar
A compression gauge
Old Mar 18, 2012 | 04:08 PM
The Grumpiest
All of this is really an exercise in futility if your boyfriend is currently working on the car arbitrarily and you are reporting things AFTER he's done them or in the middle of doing them. A waste of time all around for everybody in the thread.
Old Mar 18, 2012 | 04:10 PM
baileygirl's Avatar
Actually, I was just asking what people could think why it was doing so. So..if you honeslty dont like what I have to say then you can pretty much find a different post to comment on...HAVE A FANTASTIC DAY
Old Mar 18, 2012 | 04:39 PM
The Grumpiest
Actually, I can post anywhere that I please. It's a public forum and you people are wasting everyone's time.
