2.5" midpipe on stock cat
Old Mar 16, 2012 | 10:16 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default 2.5" midpipe on stock cat
Is this possible? I have a 2000 SI and I'm trying to put a Mugen Twinloop axle-back on. The axle back is 2.5". I was going to buy the K-Teller 2.5" midpipe section, but I wanted to make sure it will bolt up to my stock cat first.
Thanks
Old Mar 16, 2012 | 03:20 PM
BobbyRodriguez's Avatar
Default Re: 2.5" midpipe on stock cat
As long as the bolt pattern is in the same direction , shouldn't be a problem.
Old Mar 18, 2012 | 06:33 PM
2LEM1's Avatar
I like to party
Community Builder
so the cat-to-midpipe flange is the same on both 2.5 and 2.25 b-pipes?
Old Mar 18, 2012 | 06:48 PM
JDM_teh_WIN!!'s Avatar
I don't understand what you're saying. Do you have the FULL Mugen exhaust? The B-pipe and Twin Loop or just the twin loop? The twin loop is not 2.5in and will bolt up to the B-pipe.
Old Mar 18, 2012 | 07:13 PM
chewyv's Avatar
pm4nudes
Yes
Old Mar 18, 2012 | 07:22 PM
chewyv's Avatar
pm4nudes
The flange isn't welded on, so if you see that they don't fit then you just go out and get a flange that will fit.
Old Mar 18, 2012 | 08:13 PM
2LEM1's Avatar
I like to party
Community Builder
As per my original post, I have an AXLE BACK twinloop, and am looking to BUY a midpipe. KTeller has midpipes in both 2.5" and 2.25", but the 2.25" won't bolt up to the axle back.
I just want to make sure a 2.5" b-pipe is going to bolt up to my stock USDM 2.25" cat and I'm not going to have to find a 2.5" JDM cat or anything.
The only reason I'm concerned is because the Mugen twinloop is a unique piece. The B pipe actually goes from 2.25" at the cat end to 2.5" at the muffler end, unlike Spoon and other "JDM" exhausts which are 2.25" straight back.
The little info I could dig up on google gave me mixed results, and almost everyone was running a JDM cat.
Wrong. It IS 2.5" at the axle back portion, and will NOT bolt up to the stock B pipe
2LEM1's Avatar
I like to party
Community Builder
Got it I think, ty
Old Mar 18, 2012 | 08:42 PM
Really? Cause I had a Mugen Twin loop on a stock USDM B-pipe and it bolted up like stock. I know for a fact the ITR B-pipe is not 2.5in.
So, you are Wrong. And a 2.5in midpipe will not bolt on to the stock cat. I have JDM 4-1 ITR header 2.5in to 2.25in test pipe ITR B-pipe and EM1 muffler. That same exhaust had a Even rarer than your twin loop. So, I know it is not 2.5in. The entire CTR EK9 Mugen exhaust is 60mm. All Mugen twin loops bolt up to the stock B-pipe.
Old Mar 18, 2012 | 08:49 PM
And if you don't believe me why don't you actually put the muffler on your EM1. You'll see that it bolts right up. Plus if you have a stock B16A2 you don't even need a 2.5 exhaust.
Mccormick009
Nov 4, 2014 07:09 AM
Ultraspeed DC2
Jan 11, 2008 07:22 PM
Integra21
Oct 17, 2005 07:34 AM
0-400DC2-R
Sep 25, 2003 08:29 AM
2k1TypeR0610
Nov 7, 2001 04:14 AM
