Two Lug Nuts On One Tire Driveable?
Old Mar 15, 2012 | 12:04 PM
Dannyx321's Avatar
Default Two Lug Nuts On One Tire Driveable?
Ok, this is kind of a dumb question and its probably not ideal or the right thing to do.
but
Can I drive with just two lug nuts on one of my wheels? They are across from each other and its a 4x100
Old Mar 15, 2012 | 12:11 PM
liquid927's Avatar
Default Re: Two Lug Nuts On One Tire Driveable?
nooooooooooooooooooooooooooooooooooooooooooooooo
Old Mar 15, 2012 | 12:13 PM
Dc4LsTeG's Avatar
EK9
lol
doood's Avatar
been there done that
drive it straight to the store and buy new lugs
Old Mar 15, 2012 | 12:14 PM
seanzy13's Avatar
Missing one lug nut you could get by with, missing 2 on a 4 bolt wheel is just asking for trouble. Don't even try it, you'll regret it later.
Old Mar 15, 2012 | 12:19 PM
Dc4LsTeG's Avatar
EK9
Originally Posted by seanzy13
Missing one lug nut you could get by with, missing 2 on a 4 bolt wheel is just asking for trouble. Don't even try it, you'll regret it right away.
fixed
Old Mar 15, 2012 | 12:26 PM
ss_zoidberg's Avatar
Aw damnit, he's in DFW. Looks like I won't be leaving the house today.
Old Mar 15, 2012 | 01:14 PM
Turboteg27's Avatar
i had a turbo 4 door LS teg on slicks with 2 studs on every wheel lol. nothing happened but i was prolly really lucky. i had just got my new slicks, bought race fuel , and when i went to swap my street tires out for my race settup for the night i broke 2 f##kin studs on every wheel!!!
Old Mar 15, 2012 | 01:55 PM
wanabebuff's Avatar
Damn! Wtf.....2 on each wheel?? Here's how that would go down with me:
Wheel 1- "Aw crap, broke a stud off"......."DAMMIT, BROKE ANOTHER ONE OFF! (throws lug wrench)
Wheel 2- (calmed down a bit, got my **** together and started on the second wheel) "ANOTHER BROKEN STUD!!!!!" (commence beating everything I see with a lug wrench and throwing leftover parts/anything in arms reach)
Wheel 3-..........still throwing stuff and going through a temper tantrum from wheel 2
Old Mar 15, 2012 | 02:30 PM
Dannyx321's Avatar
tell me about it, im totally going to buy a torque wrench, over torque lug nuts too much
Old Mar 15, 2012 | 05:15 PM
DirtyDA9's Avatar
Not condoning this, but if you have to, obviously make sure they are diagnally across from eachother, not on the same wheel, and torque them down more than normal spec.
Old Mar 15, 2012 | 08:43 PM
01oemTeggy's Avatar
U could also grab another lug nut off ur other rim. Have two rims with three each temp till u get to the shop
Old Mar 16, 2012 | 03:45 AM
Dogginator's Avatar
Daisy... Daisy...
Hopefully the studs are not stripped, as those are a pain to change compared to just a nut. The sensible solution would be to have someone drive you to the parts store.
Old Mar 16, 2012 | 07:10 AM
98ekb18c's Avatar
Don't do it. The 2 missing lugs are across from each other, as you drive the wheel WILL slightly flex side to side and WILL break your other 2 studs. Might happen on the first trip, might last a while, but it will happen. You'll mess up a lot of stuff on your car when that wheel comes off.
Old Mar 16, 2012 | 09:58 AM
Dannyx321's Avatar
I decided i am not going to do it, but it tell me
My dad was breaking my lug nuts(has just 3 studs), he got 2 that were across from each other off, but then he try to take the last one off and he can feel it stripped and instead of taking it off he just retighten them.
Does that mean i been driving on 2 or 3 lug nut studs
Old Mar 16, 2012 | 10:01 AM
Dogginator's Avatar
Daisy... Daisy...
Fix the studs properly. Sometimes you can grind one of the corners and work it into place in the hub.
My guess is that someone used an impact wrench without a torque bar and overtightened them... more than once. I am the only owner on my GSR and can thread the lugs by hand since they were never abused.
Old Mar 16, 2012 | 10:43 AM
DirtyDA9's Avatar
Even if it feels like it's fudging up the threads, just keep unscrewing till it comes off, buy new ones and put them on, the threads will be fine.
Don't worry, I had to do that to a car at work the other day, they were hard to get off with the impact gun so I knew the threads were a little messed up, I threw new lug nuts on, they went on fairly easy and they cleaned up the threads. Not the first time I did that either, so don't sweat it, you will be fine.
Old Mar 18, 2012 | 10:06 AM
Turboteg27's Avatar
For some reason hondas are bad about the threads stripping or the threads gauling up. So Now everytime i take a wheel off i put a little grease on each stud before i put the lugnuts back on. Since ive done that i havnt had anymore problems. Just a little tip.
Old Dec 18, 2017 | 07:12 PM
Kevin Jennings's Avatar
awww greatt...this anwers another question bout some recent chanyges with wheel shake....so ya a lil bit ago puttin some douglas m~+s 185/70 r14 in preperation for the snowy time ahead up here ....lol stock suspension 95 "eg"? sedan dx....gave it agood boost from the previous....eithsr way going to unscrew one and anotber
one that followed right after when gdying to lossen abd ultimatly tak eit off, it felt like i was break in em o
in again, n eventually just snappex lug....so long ztory short ive deff putatleast almost 300 Miles so far with 2 side by side no less....on the front right tire, but gking back to what ibwas sayibg at the beggining,i got out of jail ater 33 days . no one torches her whatsoever , tjat was last thursday n ive been mobbin every day\ night n have started to heard what i think has got to be that wheel bearing now xorrect? it , so pretty mucb now bu truing to avoid thw pain n the butt it is tp get it all the way apartvdown to all that n not wanting to ravish the hub with a drwmel.......if it wven last that long. ima have to do it all now huh
Old Dec 18, 2017 | 07:16 PM
the line of buisness i endivin keeps me on the move to say thw last , so unless i had a storage unit thats prob about the only place, man these gangs run up on u n ur vehicle outbod commision toast, if if while there hushing u out kf there turf thats all bad bad bad u kno?
Old Dec 18, 2017 | 09:36 PM
MotorMouth93's Avatar
10 Year Member
What the **** is this ****?
Old Dec 19, 2017 | 05:19 AM
CandyRedRC46's Avatar
We really need to start I.Q. testing new members....
Old Dec 19, 2017 | 05:26 AM
dc2_tracktoy's Avatar
What the actual **** did I just attempt to read...?
Old Dec 19, 2017 | 10:22 AM
thewrai6th's Avatar
Ebonics chat bot? Completely incoherent bump on a 6 year old post.
He probably would have been better off staying in jail.
Old Dec 19, 2017 | 10:29 AM
I think someone had a stroke and tried to get on Gizzogle to get help and ended up shitposting on Honda Tech lol
tallblondkid
Jun 5, 2011 08:56 AM
99 TW EJ8
Oct 15, 2009 02:25 PM
Lil_Wyte
Apr 11, 2009 01:17 PM
boostincoupe
Jun 30, 2008 06:03 PM
kyteggy
Feb 5, 2006 01:39 PM
