Air Idle Control Valve Delete?
Old Mar 15, 2012 | 08:43 AM
Shadowcat's Avatar
Default Air Idle Control Valve Delete?
Ok so i have a 95 civc eg with a jdm b16a in it and my IACV is acting up and the idle is pulsing from 1100 to 1300 rpm so instede of paying 200 bucks and I just block it off like people do with the fast idle thermo valve? And I could not find a diagram of the vacuum lines just incase the lines are hooked up wrong. A little help please
Old Mar 15, 2012 | 03:00 PM
hondamark35's Avatar
Default Re: Air Idle Control Valve Delete?
this will not work. you will not fix your issue. find a good used valve and fix the problem.
Old Mar 15, 2012 | 03:53 PM
h0p3l355dork's Avatar
you don't have to actually get a new one, try cleaning it! Check the FAQ for cleaning guides for IACV's
Old Mar 15, 2012 | 04:00 PM
92teginsc's Avatar
you could also tap it with a hammer and it will knock some of the carbon out, or so ive been told. im also gonna get an used one from a junkyard insted of paying almost $200 for a new one.
Old Mar 15, 2012 | 06:46 PM
mitchk90's Avatar
Grab a 5 dollar can of carb cleaner and clean it. Reset your computer and away you go.
Old Mar 16, 2012 | 07:49 AM
Shadowcat's Avatar
One of the first things I did was spraying carb cleaner in it. So I guess iobtake the whole thing off the car and realy scrub it down. Thanks guys. Ill keep u posted
Old Mar 16, 2012 | 09:26 AM
Shadowcat's Avatar
ok i just got done cleaning the entire valve. here is also a vid of what it is doing it might help.
http://www.flickr.com/photos/6912156...in/photostream
95gsr@530
May 13, 2019 10:43 AM
xlusiveracer
40
Jan 23, 2017 09:32 PM
Thatssojdm
Aug 3, 2008 08:29 PM
LD_EGSICK
15
Aug 5, 2003 10:35 PM
Hondaaccordvtec
May 19, 2003 06:13 PM
