one high beam wont work??
Old Mar 15, 2012 | 08:10 AM
thelostafrican's Avatar
Icon6 one high beam wont work??
So recently my left high beam on m 94 civic DC 2 door sedan went out all the other light s work including. The right high and low beam I checked fuses none were burned out ( also I don't know if its relate but the dash highbeam inidicator doesn't work
Old Mar 15, 2012 | 03:56 PM
h0p3l355dork's Avatar
Default Re: one high beam wont work??
Check the bulb?
Old Mar 20, 2012 | 12:19 PM
yeah the bulb works fine. The low beam works. but not the high beam i swithched it to the other side and the high beam worked there so there is no prob with the bulb
Old Mar 20, 2012 | 03:34 PM
Maybe the wire is cut somewhere along the line? DO you have access to a multimeter? Also make sure you actually test the fuses. I don't think it would be a fuse just because one works and the other doesn't.
civicx
Dec 13, 2016 05:32 AM
jonny11844
Feb 23, 2014 05:14 PM
zombie500
Nov 9, 2013 04:21 PM
JJ's civic
Nov 29, 2008 12:23 PM
EH2_pReStO
Nov 21, 2003 02:28 PM
