Driver Door Speakers not working
Old Mar 15, 2012 | 06:39 AM
ctag's Avatar
10 Year Member
Icon2 Driver Door Speakers not working
Old Mar 15, 2012 | 06:43 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Driver Door Speakers not working
I'm guessing all the wires were cut and spliced (hacked)?
Old Mar 15, 2012 | 07:00 AM
motegicivic's Avatar
I assume the door speakers are powered off the factory wiring (not rewired into the door?)
Did they cut the factory plug in the door?
Look closely at the factory plug if still there, you will have 2 wires coming in and 2 wires going to the factory tweets, are all the wires still intact?
My point is if any were cut you should get the colors for the wires coming into the doors put some spades terminals on them and plug into the speakers and see if you hear anything.
ctag's Avatar
10 Year Member
Old Mar 15, 2012 | 07:44 AM
ctag's Avatar
10 Year Member
Old Mar 15, 2012 | 10:47 AM
ctag's Avatar
10 Year Member
Old Mar 15, 2012 | 11:22 AM
Originally Posted by BigBubbaX
Okay, I think I found something:
I got the fender off and took the rubber tube off of the door and pried back the rubber to get at the wires.
Three of the wires popped out immediately. But none of them were the red or brown ones I'm looking for. Actually, I don't see the red or brown ones anywhere in the mess of wires going from the car to the door. . . Where'd it go?
Aaand. . I'm stuck again, I don't know how to re attach the loose wires when the entire connector is covered in this grease sealant stuff
Super typical, that is such a pain. As for the colors not matching, the inner door might be a different color.
You can go to a junk yard and cut off a plug and solder to your car.
You can repin yours, sort of a pain to do it.
Or you can buy a new floor harness from honda still a pain.
Old Mar 16, 2012 | 05:04 AM
ctag's Avatar
10 Year Member
Old Mar 16, 2012 | 09:26 AM
x_x Thanks for the options. Yeah, this is going to be a pain
I pulled the male socket out of the door and checked the wires. They're all different Which means that the red and green one that I traced all throughout under the dash magically disappeared in the hinge tube and shows back up in the door. .
But I found where it was missing from the car-side of the connector, and found where the ground wire was (luckily, still intact) so then I tested each of the three loose wires with one of the speakers and found one that worked
As a temporary fix, I jammed a big piece of copper wire into the red/green wire's socket and tried crimping it with a knife, then soldered the working wire to the copper, put the rubber back on, plugged everything up, put the fender back on, put the front bumper back on, put the side skirt back on, put the door panel back on, put the wheel back on, put the speaker back in, and played music
I never found out what the two remaining wires were for, everything works on the door: window, locks, whatnot. (maybe it's the power-mirror :-\ I'll check)
I guess my next step is to figure out how to replace that plug before my shotty wire fix gives way...
Could be for the power mirrors, test them.
Good idea just using some copper wire, at least get some music.
Old Mar 19, 2012 | 03:49 AM
ctag's Avatar
10 Year Member
Old Mar 19, 2012 | 04:16 PM
Go to a junk yard cut as much off the donor car and solder it on, cheaper that way.
Old May 24, 2012 | 08:21 AM
EJ2GOON's Avatar
damn, i need help with this too.................my speakers would keep messing up sometimes when i would turn...........now only my left door speaker works, but sounds shitty........please help.
Old May 28, 2012 | 03:23 PM
ctag's Avatar
10 Year Member
siteshahid
Mar 17, 2013 07:10 PM
Gsrsi
Audio / Security / Video
11
Dec 5, 2012 07:09 PM
nontent
May 15, 2004 07:34 PM
ninja8oi
Mar 23, 2003 03:03 PM
MilanoRex
May 19, 2002 08:53 PM
