97 civic dies after starting and running a couple minutes
Old Mar 15, 2012 | 06:08 AM
Joshua Howard's Avatar
Default 97 civic dies after starting and running a couple minutes
I have a 97 civic with a d16y8 and its starts fine and runs fine for about ten minutes. After it has been running the rpms drop the car sputters and dies. While the rpm are dropping it will not respond to the gas or clutch pedal being pressed.
If I wait about 5 min and start it again sometimes it will start and drive sometimes it will repeat the previous process and I will have to wait ten minutes. I bought this car in September (it did it twice) and it has done it twice this week.. It has not had the issue at all over the winter but now the weather is warming up (60's - 70's) and it is starting to do it again.
I have read through the boards and I am thinking maybe main relay but honestly I have no idea.
Old Mar 15, 2012 | 07:04 AM
motegicivic's Avatar
Default Re: 97 civic dies after starting and running a couple minutes
Rare for this generation to have main relay issues.
Any CEL's?
I would test the coil and then ICM.
Old Mar 15, 2012 | 07:27 AM
I had an issue over the winter one time where the car wouldn't start but had power when the key was turned to on. When o yried to crank it, it wouldn't turn over. I tried jiggling the key as I started it and it fired up. Are you thinking maybe it is the ignition?
Old Mar 15, 2012 | 07:30 AM
Automatic transmission cel's (ppl that had it before me took the ecu out and put that in). I have a new ecu coming tomorrow. I'm going to check the solders on the main relay just to make sure its good.
Old Mar 16, 2012 | 03:53 PM
MikesEJ1's Avatar
try fuel pump
Old Mar 20, 2012 | 05:15 AM
Update* changed out the fuel filter over the weekend, still having an issue. Like what was stated above I think I have a weak fuel pump, I will try that tonight and update... I love hondas.
Old Mar 20, 2012 | 06:00 AM
delsoltech's Avatar
Yeah, fuel pump came to my mind first. Let us know
Old Mar 24, 2012 | 04:50 PM
bigpunn421's Avatar
mine does this same thing but only once its warm. if its cold it doesnt surge/sputter
raidacaipo
Aug 27, 2014 02:20 PM
sniper_king
Aug 26, 2013 09:42 AM
NemesisVette
49
Jan 3, 2013 12:37 PM
spence19
Jul 23, 2006 02:45 PM
FLCivic
Mar 27, 2005 07:37 PM
