JDM "R" 5-lug (Has bigger Axles fo Realz)
Even though i read a thread on here a while ago about JDM 5-lug having bigger axles i wouldnt believe it until i tried it myself, and sure as **** my B-series 32mm U.S spec axle is way too small. So now i am up the creek without a paddle. Hopefully i can hunt down a set of JDM 36mm axles......
<-------Learned the hard way.
Ed, contact Larry Jr. at Import Auto Salvage (1-800-962-8922). He has tons of JDM "R" front clips in the Type-Arr graveyard. He might have front assembly w/ axles.
I think that you can hybrid some axles that use the prelude outer joint. I think that the "stub" is the same size as the 98 up R.
Someone else might know more specifics...
JDM front clips? wow.. including the body panels? where is this guy located?
Thanks for the tip Ian.
I ordered an "Endyn" breather kit from them not long ago.
I'm looking for some bigger axles to go with big boost, since I do't like fixing things while on the road.
Ed, one thing about the axle is the main shaft is not bigger, but only the input into the hub is 4mm larger.
Other than that I was going to send the stubs (tranny side and hub side, for each axle) out to get cryo'd and hope for the best.
