Killer Darton Sleeves, rods and pistons Combo Sale! For F and H-series!
Only 2 complete set of Darton M.I.D sleeves available, First come first serve!
Call 888-922-6686 to place order or email Sales@Bisimoto.com
Darton M.I.D. Sleeves H22, H23 or F22 $649 shipped to Continual USA!
Bisimoto Killer Combo for H22
- Bisimoto Forged piston kit 87.5mm bore
- Bisimoto Steel H-beam rods with ARP2000 rod bolts
- Darton Sleeves (Requires installation by your local machine shop)
- Compression ratio's available 11:1, 9.2:1 and 8.4:1
- $1,449 with FREE SHIPPING to the Continental USA!
- ADD $189 for custom bore size and compression pistons (3-4 weeks to manufacture)
Bisimoto Killer Combo H23A1
- Compression ratio's available 12:1, 10.7:1 and 9.2:1
Bisimoto Killer Combo F22A/B
- Bisimoto CUSTOM Forged piston kit with your choice of bore size and compression ratio! (Bore size must be 87.5mm or larger)
- Bisimoto Custom Long Steel H-beam rods with ARP2000 rod bolts
- $1,599 with FREE SHIPPING to the Continental USA!
- Take 3-4 weeks to manufacture pistons
Bisimoto Spec. Steel rods are manufactured from the very best aircraft quality 4340 steel. Using Autocad 14 technology, the Bisimoto Spec. rods are lightweight without sacrifice of strength. Rods and rod big end caps are forged in separate processes for optimum internal grain flow and structural integrity. The Bisimoto Spec. steel rods feature 3/8" diameter ARP bolts and have been tested to over 800 HP on a proper tune. Ideal for street, strip, road race, auto-x, time attack and full power competitions...n/a or boosted.
The small end bores feature bronze pin bushings for floating pin applications, with proper oiling orifices: perfect for shelf and custom forged pistons, providing amazing lubrication qualities in the most extreme performance applications.
Bisimoto forged pistons grace the most powerful all motor, gasoline and alcohol powered sport compact engines on the planet! Race spec pistons feature aluminum wrist pin buttons, ceramic coated domes, moly coated skirts, flow bench designed high compression domes, and can be configured for 2 and 3 ring designs. Shelf units incorporate pin locks. Bisimoto Spec forged pistons are manufactured exclusively by Arias Pistons, with compressions ranging from 9 to an astonishing 17.0:1. These specialty pistons can accomodate up to 3mm oversize valves and strategically lightened to provide optimal weight savings without compromising strength intergrity. Gains exceeding 8% have been documented with this piston technology in comparison to competitor shelf units. Serious inquiries only.
FREE Bisimoto accessory package with the purchase of any Bisimoto camshaft, Bisimoto Header or any purchase over $349!
Must mentioned Bisimoto Accessory Facebook Special* in check out notes on online orders through Bisimoto.com or over the phone orders at 888-922-6686!
Includes:
Bisimoto Brake/P.S. reservoir sock
Bisimoto License plate frame
Bisimoto bumper sticker
Expires: 4/30/12
Includes:
Expires: 4/30/12
Includes:
Expires: 4/30/12
Includes:
Expires: 4/30/12
Includes:
Expires: 4/30/12
Includes:
Expires: 4/30/12
