h22a head decking and compression ratio
Old Mar 14, 2012 | 02:48 PM
coomplife05's Avatar
Default h22a head decking and compression ratio
I got a h22a eg with a built head and stock block with a few good boltons. I got a dhracing 1layer hg for a compression bump to 11.1:1 but I'm doing a rebuild and wanted to know what's a good,safe and the max amont to deck the head and what kind of compression ratio I would be at and how much pressure is too much for these notoriosly weak h ringlands......chime in
Old Mar 15, 2012 | 09:25 AM
Default Re: h22a head decking and compression ratio
So no one here has ever decked a head for an all motor setup it seems like.......bump
Old Mar 15, 2012 | 09:53 AM
andoxviii's Avatar
You might have more luck in the All Motor forum.
Old Mar 15, 2012 | 10:13 AM
Basik_One's Avatar
Only thing that comes to mind is check your p2v clearance
Old Mar 15, 2012 | 08:41 PM
jdm_rb20's Avatar
p2v = *boom*. :0
buy some clay or some playdough or something and check your current clearance. If your compression is already 11:1, then your p are probably dangerously close to your v (giggity). And, iirc, a "built" head usually means that you can expect your v's to open farther down than a stock head (my apologies if I am wrong on this...i am just a hobbyist).
Basically, I think you are on a thin layer of ice and you are moving towards thinner ice. USE THE CLAYY!! (haunting echo voice)...lol
--TJ
Sparksman
44
Jan 9, 2014 12:46 PM
coomplife05
Mar 15, 2012 06:00 PM
Techna600f4i
Jun 19, 2006 11:49 PM
Bombino
Apr 15, 2002 01:13 PM
