Skunk2 Intake Manifold on 96 JDM GSR... NEED HELP!
Old Mar 14, 2012 | 07:39 AM
ej94coupe's Avatar
Default Skunk2 Intake Manifold on 96 JDM GSR... NEED HELP!
Hello everyone I have 94 Civic ex with a JDM 96 GSR swap. I recently installed a Skunk2 Intake Manifold and i am having an over heating problem. I am not sure but i think its because of the hose that comes under the distributor cap is plugged. If someone could please help or even show pictures it would be great. I would like to get this solved soon since Honda day is not to far away.
Thanks in advanced
Old Mar 14, 2012 | 07:48 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: Skunk2 Intake Manifold on 96 JDM GSR... NEED HELP!
Thank you. Is it possible for you to post a pic of the hose your speaking of that is plugged?
You aren't speaking of the hose that attaches to the thermostat are you? Because that would def be an issue!!!
Old Mar 14, 2012 | 08:17 AM
ej94coupe's Avatar
No problem. This is the plug that is under the vtec soleniod. I was told that i can bypass it. Is that right?
Thanks for your help bro
Old Mar 14, 2012 | 08:22 AM
ej94coupe's Avatar
http://s1252.photobucket.com/albums/...t=IMAG0140.jpg
Also if i am leaking a little bit of radiator fluid could that also be the cause?
Old Mar 14, 2012 | 08:53 AM
NVturbo's Avatar
O.G. triple O.G.
That hose is for the heater core. You can leave it off but make sure you're not losing coolant. If there is coolant visible, add some more and bleed the system to be sure.
Old Mar 14, 2012 | 08:54 AM
ej94coupe's Avatar
Ok so that little plug can be capped?
Thanks Bro
Old Mar 14, 2012 | 08:55 AM
NVturbo's Avatar
O.G. triple O.G.
Yes, just make sure the plug is on there tight and no coolant is leaking.
Old Mar 14, 2012 | 08:59 AM
ej94coupe's Avatar
Perfect thanks Bro. Also just one more question. On the new Intake manifold there is 2 inlets a big that plugs right onto the block and the little inlet plugs into the TB right?
http://3.bp.blogspot.com/_dEdAmzkIt0...03+%284%29.JPG
Old Mar 14, 2012 | 10:32 AM
BobbyRodriguez's Avatar
You really don't need any of those coolent line to run your motor safely. Just a radiator and inlet and return.
Old Mar 14, 2012 | 10:47 AM
ej94coupe's Avatar
Kool, Thank Guys. I will let you guys know how it goes.
I appreciate the help
GeorgiaSTi06
Aug 3, 2008 04:26 PM
eg6hatch
11
Feb 12, 2004 06:20 PM
