machine shop cost..
Old Oct 10, 2002 | 03:49 PM
Adriano's Avatar
Default machine shop cost..
how much would it cost if i took my block to a machine shop so they could change my piston and rods. i want to rebuild my motor. I will take it out, and take the head off, and the rest of the stuff out (alternator, ...) but i dont feel confortable messing with the internal. Around how do you think it would cost. No boring or anything, just take the old ones and out the new ones in. thanks
Old Oct 10, 2002 | 03:54 PM
tonyxcom's Avatar
Default Re: machine shop cost.. (brryder)
you thought about calling a local machine shop in your area?
I would recommend you let them measure your cylinder bores first before you buy new pistons because you may need to go oversize for the correct tollerances. You will almost always need a hone as well.
I imagine if all you needed was a hone that it would cost under 300 for labor. At least that is about what it would cost me.
Old Oct 10, 2002 | 06:25 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: machine shop cost.. (tonyxcom)
Cleaning, honing, and boring 20 over was only $180 for me.
Old Oct 10, 2002 | 06:32 PM
tegasaurus's Avatar
Default Re: machine shop cost.. (shamoo)
did you drive your car there or did you already have the block out and just shipped it to them?
by the way, nice rims
[Modified by tegasaurus, 7:56 PM 10/10/2002]
Old Oct 10, 2002 | 07:44 PM
shamoo's Avatar
Default Re: machine shop cost.. (tegasaurus)
I had everything out and separate already. I just handed them the block, and picked it up after it was done. Granted, it took them about 3 weeks, but it was a small family business and they only charged $180.
Thanks.
Old Oct 10, 2002 | 10:21 PM
Vertigo's Avatar
Disassenble short block(Do it yourself, take off EVERYTHING)-50.00!!!!
Hot tank block-40.00
Hot tank crank-15.00
Bore, hone block-100.00
Balance rotating assembly-150.00
Polish crank-25.00
Transfer pistons-20.00
NoWorry's
Apr 25, 2013 06:50 PM
killerpenguin21
Jul 23, 2006 08:54 PM
turbahatch
Apr 1, 2006 01:02 AM
sporkcrx
Sep 27, 2003 01:43 PM
