95 civic dx with d16y7 swapped obd1 misfiring
Old Mar 13, 2012 | 09:14 PM
j17mej2's Avatar
Default 95 civic dx with d16y7 swapped obd1 misfiring
I got a 95 civic with a y7 swap. Has brand new spark plugs,wires,cap,rotor, fuel filter, fuel pump, just put on a blox fuel pressure regulator also. .. . Been having this problem for about a month now and still no luck car bogs at a stand still unplugged all wires to test out spark and the 4th cylinder I believe closest to distributor bogs the same even when plugged and also I have a cell code 43 which I don't understand cause I've changed everything that has to do with fuel. .. . I've gone through every thread and the last thing on my mind is a compression test so I'm hoping to do that this weekend. .. .
Old Mar 14, 2012 | 10:35 AM
j17mej2's Avatar
Default Re: 95 civic dx with d16y7 swapped obd1 misfiring
So I've fixed the bogging problem and now it shows a code 43 any ideas furl pump fuel pressure regulator fuel filter are all brand new. Injectors were swapped out with known good ones next step is to check my cat and o2 sensor since everyone is saying it can be that.
Joe Yaerrd
Mar 8, 2017 03:58 PM
EFb18b
Aug 2, 2015 04:28 PM
hondagirl86
10
May 12, 2014 02:35 PM
freydaddy
12
Nov 21, 2010 09:04 AM
specie
Nov 1, 2003 11:23 AM
