SOHC vtec into a 87 possible??
Old Oct 10, 2002 | 03:47 PM
JCracer723's Avatar
Default SOHC vtec into a 87 possible??
has any1 done it? or know any1 that has done i t?? just wonderin
Old Oct 10, 2002 | 04:29 PM
kai's Avatar
kai
Default Re: SOHC vtec into a 87 possible?? (JCracer723)
As a complete swap, no, it is not possible. The motor mounts changed completely between 87 and 88, so any 88 or newer engine will not "bolt in." I am still trying to figure out if a mini-me style head swap is possible though, but going from preOBD to OBD1 is a killer... does anyone know if I can wire an OBD1 TPS into a preOBD (86-87 Civic Si) ecu, or would the voltages be off? What is the differences (flow rate, and impidence) between preOBD, OBD0 and OBD1 cars? Finally, what the hell can I do about the vacuum advance distributor? If I can figure these things out, I might try to mini-me my 87 Si.
Old Oct 10, 2002 | 05:18 PM
Qfactor's Avatar
you will have to make custom made engine mounts to drop it. that will be a nice set up, or you can go with a B or H series engines as well it's all up to you.
Old Oct 11, 2002 | 01:59 PM
JCracer723's Avatar
Default Re: SOHC vtec into a 87 possible?? (Qfactor)
i found this
http://www.geocities.com/crx1stgen/1stGenHybrid.txt
Old Oct 11, 2002 | 02:08 PM
OldSchoolCrxSiR's Avatar
just swap in a D16A1 out of a 87-89 integra! it is worth it believe me!
Old Oct 11, 2002 | 06:53 PM
Default Re: SOHC vtec into a 87 possible?? (OldSchoolCrxSi)
i am in 13's no problem! so i mean depends on how much money you got! my car in total with everythign is about 3000!
Old Oct 11, 2002 | 07:43 PM
MrTodd's Avatar
I like your list of mods on the 1g! You should go on a road trip all the way over here and let me drive your old skool rex!
Old Oct 11, 2002 | 07:52 PM
Default Re: SOHC vtec into a 87 possible?? (MrTodd)
actuall i am going on a road trip out to canada maybe i could get a little off track!
crx-ricki
Classic Hondas
Mar 9, 2013 12:20 AM
hey jay
Nov 1, 2005 07:19 PM
B_CRUZ!
Jun 25, 2003 09:39 AM
spiceisler
Mar 11, 2003 01:26 PM
