93 Honda Civic Si B16A Motor Swap
Old Mar 13, 2012 | 08:07 PM
barr90's Avatar
Icon2 93 Honda Civic Si B16A Motor Swap
I just bought a 93 civic si and it has a brand new b16a shipped from japan put in it. The motor mounts need replaced on it and I am not sure if I should go with the stock motor mounts for the si or get the b series motor mounts. Because right now it has the stock mounts on it, but I am wondering if that is the reason they are busted. Actually only the front left one by the driver side tire is blown out and the front right by the passenger side tire is just a little worn and cracked. Should I replace them all at once and which kinda should I get??
Old Mar 14, 2012 | 04:38 AM
kp's Avatar
kp
Default Re: 93 Honda Civic Si B16A Motor Swap
Sounds like a troll thread but I'll give it a go. You're saying it has a "brand new" B16 in it? If the motor is already in, it should be installed with B-series mounts. If you think they need replacing, you'll need B-series mounts.
MDmedicalCard
Nov 18, 2017 06:05 AM
madmantrapper
Honda Civic (2006 - 2015)
Apr 8, 2014 09:41 AM
del_sol 2009
Mar 9, 2009 02:31 PM
