how to take 100lbs that you cant see
how can i take 100lbs out my car that i wont see
its a 1994 accord lx 4dr the car is 3010 with every thing in it but with all the audio out the trunk 2940 am trying to get 2800 with all my seats in there i took out the AC all ready what can i remove
i can drop 40lbs by putting the slicks on
so 100lbs more
so 100lbs more
I think you can take out the metal backing plates in the front seats. Drill holes throughout the chassis. Pull out the interior and melt the tar away. Remove battery after you start the car
or just get one like 2point6 has. Magnesium wheel lugs and lighweight rotor hats. Get CF parts and paint them.
why don't you just get rid of unspring weight (weight in the wheels).
saving every pound of unspring weight possible (without compromising safety and durability) makes a much bigger difference than removing weight from inside the car.
it also helps braking tremendously.
Move as much weight to the center of the car. If you have a toolbox in the trunk, somehow strap it down on the floorpan behind the front passenger's seat. Remove anything heavy uptop (i.e. put the Thomas Guide on the ground and off the top sill). Recline your passenger seat all the way back. Try as much to get weight low and to the center of the car. Get that **** out of the glove-box.
Edit: Do you move it all the way back or forward? I'm guessing back because more weight is in front. LMAO!
[Modified by Wont be beat, 12:45 PM 10/11/2002]
Thats hardcore gangsta y0!
Only the HaRDcORE Biatch!! hahahaha
Si2See
Nov 29, 2003 02:26 PM
mrnicolas
Jan 18, 2003 08:39 PM
