INTEGRA WONT TURN OVER ?
whats up i just fixed one of the problems with my car now a other poped up its not letting me turn it on ???
like thursday i was driving it fine and the friday morning nothing it cranks but will not turn oer ??
ive tryed buying new fuel pump and main relay and even trying starting fuid nothing ????
what u guys think ??
and its a 93 integra ls
I do wish you kids would learn to write. "Crank" and "turn over" are the same thing.
Which of these three do you mean?
1) You hear and feel chugga-chugga noises from under the hood, and the engine coughs and sputters but does not start?
2) You hear and feel chugga-chugga noises from under the hood, but the engine does not cough, sputter, or show any sign of wanting to start?
3) You do not hear or feel anything from under the hood except maybe clicks, or a chattering noise?
My buddy's GSR had the same problem. Here's my two cents on this, maybe your dizzy is bad? Also on Civic (DD) he had carbon build up causing it not to start either. Correct me if i'm wrong.
Well since you are getting spark then your dizzy isn't bad so knock that out of the scenario. Carbon could build up on the pistons, exhaust ports or even on the spark plugs. Once again you said you're getting spark so spark plug build up isn't a factor either. I have never cleaned anything that had carbon build up and I'm not sure what exactly my buddy did. I would check to make sure everything is in time, that could be a possible factor as well.
JDMSTATUS425
Aug 18, 2008 08:13 PM
