Exhaust Smell Inside the Car
Old Mar 13, 2012 | 10:55 AM
Phr33l's Avatar
Default Exhaust Smell Inside the Car
Hey Everyone. I wanted find out what could be the reason why the interior of my car smells like gas every time I drive the car. After 20 minutes of driving I smell like gas. Do you think the exhaust has a leak?
Old Mar 13, 2012 | 11:12 AM
Former User's Avatar
Default Re: Exhaust Smell Inside the Car
Does it smell like raw gasoline or rich exhaust fumes? Check for a fuel leak around the fuel filter and an exhaust system leak.
Old Mar 13, 2012 | 11:22 AM
Dc4LsTeG's Avatar
EK9
Car wire tucked? Check for exhaust leaks
Old Mar 13, 2012 | 02:10 PM
jbpnoman's Avatar
Wait, in the title you said it smells like exhaust, but in the post you said it smells like gas. Which one is it?
Old Mar 13, 2012 | 03:01 PM
Phr33l's Avatar
Sorry it smells like exhaust fumes. I'm jacking up the car later tonight and will inspect the exhaust pipes.
Old Mar 13, 2012 | 05:36 PM
redm3turbo's Avatar
any cel? perhaps cat conv clogged
exhaust pipe you'd more then likely hear any holes.
Old Mar 13, 2012 | 07:14 PM
phat00civic's Avatar
I have the same issue, but I run a bit rich. Do you have any mods? Check the header / manifold if you have a turbo to see if its leaking there or like you noted under the car.
Old Mar 14, 2012 | 02:30 PM
Phr33l's Avatar
Jacked up the car and and found out that each end of the resonator has huge crack. I'm bringing the car in to my mechanic and he will take this out and custom make a straight thru pipe. Thank you everyone for the input.
motegicivic
13
Nov 8, 2011 09:16 AM
5thgen_er
Aug 31, 2009 02:26 PM
floatfisher
Sep 3, 2006 06:30 AM
ItalynStylion
Feb 19, 2005 10:57 AM
Chief Brody
Aug 23, 2003 01:55 AM
