B16-R Stoker .. How much to the wheels...?!
Old Oct 10, 2002 | 03:24 PM
DynamiteSJ's Avatar
Default B16-R Stoker .. How much to the wheels...?!
I been looking around the net for Dyno sheets on the results of a Stroked B16 motor but having troubles to find...
What i got right now is.. Stock B16 bottom block with a Type-R head.
Skunk2 Stage 2 Cams
AEM Cam Gears
ITR Intake Manifold w/ Throttle Body
DC 4-1 Headers
Test pipe
DC Exhaust
Venon Hi-Flow Fuel Pump
AEM Fuel Rail w/ Ajd Fuel Pressure Regulator
Full MSD System w/ 6AL
AEM Cold Air
Any Estimations on how much HP should be at the wheels w/ a stroker kit?
Tryin to find out if its worth it or just get a GSR / Type-R Block instead...
Old Oct 10, 2002 | 03:32 PM
ExospeedAMcrx's Avatar
Default Re: B16-R Stoker .. How much to the wheels...?! (DynamiteSJ)
it will all depend on the Compression ratio and other factors.
I'd ratehr just get a sleeved overbored block than a stroker block.
theres stroker kits out there but for reliabilty i believe a sleeved b18 bored to a 2.0 is better for daily driving.
Old Oct 10, 2002 | 03:47 PM
dohcsideSi's Avatar
Default Re: B16-R Stoker .. How much to the wheels...?! (exospeedAMcrx)
ITR block less money...more reliable
Old Oct 11, 2002 | 10:04 AM
vtecvoodoo's Avatar
Future Texas Boy
Sleeve a b18 and go 2.0.
Ryan
Old Oct 11, 2002 | 10:40 AM
CHEETAH's Avatar
stroked b16 to 1.8 liters will result in about 10 lb-ft more torque and about -5 hp less than the b16a.
basically that $2 grand you'd spend for the stroker kit, you could have picked up a stock LS block and put your stock b16a P30 pistons in to make more power.
the comparison above are with sotck b16a camshafts.
Greg
Cincykemo
Engine Machining & Assembly
Apr 30, 2016 11:01 PM
v1sion
Feb 10, 2011 05:03 PM
stpacura
Jan 12, 2008 07:38 AM
nonoy93cvc
11
Oct 8, 2005 09:08 AM
1996GsrVtec
Jun 16, 2002 10:22 PM
