Cast piston power limit on E85?
Old Mar 13, 2012 | 08:19 AM
Aesthetic Gains's Avatar
Dos Pupusas
Default Cast piston power limit on E85?
Hello guys,
I was wondering what you guys usually push cast pistons to, using E85?
Specifically non-vtec cast pistons.
Old Mar 13, 2012 | 11:35 AM
racebum's Avatar
Default Re: Cast piston power limit on E85?
have personally seen them go as high as 440whp on e85. that was on a gsr. if you have an LS you'll probably break a rod before the piston goes provided you don't have some crazy tune that provides detonation.
detonation and cylinder heat are how you kill cast pistons. run lean or detonate under boost and they are done
Old Mar 13, 2012 | 05:56 PM
Turbo-LS's Avatar
LS pistons have weak ringlands and don't like timing. 300-325 is a safe amount on pump gas and can't imagine much more on e85
Old Mar 14, 2012 | 05:22 AM
D-Rob's Avatar
We've had them as far as 500whp on 93 octane. Nippon Racing cast PR4's in an LSVTEC.
With E85, I'm betting they'll go further.
Old Mar 14, 2012 | 05:45 AM
Turbo-LS's Avatar
The Nippons are similar to the stock pistons but im pretty sure they have thicker ringlands
almostjdmeg
Aug 21, 2008 08:22 PM
melovesboost
Feb 5, 2007 12:10 PM
lsvtecej6
11
Aug 20, 2006 06:58 PM
SPOOLINmatt
Jan 13, 2006 06:13 AM
PrecisionH23a
Mar 17, 2005 06:12 PM
