What paint gun do you use?
Old Mar 12, 2012 | 08:45 PM
R.sok's Avatar
Default What paint gun do you use?
I'm on a budget & I'm looking for personal references to a cheaper paint gun.
I will be spraying a Urethane clear & a Polyurethane Basecoat in my garage.
Price ranged is between 0-120 maybe? The gun doesn't have to last super long although there is a possibility I might do everything piece by piece using a solid color. Would this possibly suffice? http://www.ebay.com/itm/10pc-HVLP-PA...95bb5a&vxp=mtr
Old Mar 12, 2012 | 08:47 PM
joeshmo's Avatar
Default Re: What paint gun do you use?
What is far more important is how powerful a compressor do you have?
Old Mar 12, 2012 | 09:12 PM
R.sok's Avatar
I can't remember off the top of my head, it's a devilbiss pro 4000 12 gallon 4hp
Old Mar 12, 2012 | 09:15 PM
joeshmo's Avatar
220v or 110v?
Old Mar 12, 2012 | 09:17 PM
R.sok's Avatar
110v
Old Mar 12, 2012 | 09:18 PM
joeshmo's Avatar
Hmm. Well if you are doing panel painting and not all over jobs, you'll probably be okay with a gun around 10-14cfm.
Old Mar 12, 2012 | 09:31 PM
R.sok's Avatar
90psi 5.8 40psi 7.8
Old Mar 12, 2012 | 09:38 PM
joeshmo's Avatar
Things you can try:
Look on craigslist for a SATA or IWATA gun, used but in good condition. These guns are great and last forever.
Try el cheapo guns from HF on a few pieces. Most have a crappy pattern and are inconsistent but depending on what you have lined up, might fit the bill. The HF mini "detail" gun is actually fine once you use tape to seal the cup threads.
Get a starter kit from devilbiss. Suitable candidates:
Higher end gun: http://www.amazon.com/DeVILBISS-Fini...1616931&sr=8-1
Lower end gun: http://www.amazon.com/Devilbiss-Star...1616931&sr=8-5
Get this LVLP gun. It is a good gun, won't last forever but has very low draw so doing an all-over paintjob would be easy.
http://www.amazon.com/Grizzly-H7666-...4&sr=8-1-spell
The kit you posted is probably the same one as made by vaper. Overall they are decent quality but they don't last long and are usually machined poorly (gotta check the nozzle holes to make sure they are clear on the cap and check the spray pattern between coats.)
Old Mar 13, 2012 | 01:17 AM
R.sok's Avatar
Thanks for the advice. I think I'm set on the sharpe fx3000
Old Mar 13, 2012 | 08:29 AM
Builda'Teg_92's Avatar
^^ thats my gun Also i would suggest not doing the paint job piece by piece, if i were to go back i would just spend the extra hours and mask the **** out of it. Espically if its your first paint job. check out my thread in my sig to see what im talking about.
Old Mar 13, 2012 | 07:33 PM
R.sok's Avatar
How do you like the gun? I was planning on doing my lip, front bumper, rear bumper, trunk all off the car, It's a solid black color so I don't think color matching would be an issue?
jayturboef
Paint and Body
20
Apr 20, 2010 11:39 PM
tthomass
Jan 10, 2006 03:44 PM
AZNracerx1989
Dec 6, 2005 11:35 PM
modulo_s
Honda Motorcycles
May 23, 2005 08:58 AM
HamiltonRex
Jul 17, 2004 06:13 PM
