94 accord ex 4 dr driver side doesnt unlock the other doors
Old Mar 12, 2012 | 08:01 PM
cd5lover's Avatar
Default 94 accord ex 4 dr driver side doesnt unlock the other doors
on the passenger side door i can lock and unlock all 4 drs with key but on the driver side door i can only lock all 4 drs but cant unlock the 3 doors with key
eny idea
Old Mar 12, 2012 | 09:36 PM
professorman's Avatar
Default Re: 94 accord ex 4 dr driver side doesnt unlock the other doors
It is a safety feature. The driver door is a two function lock. Single turn of the key unlock driver door only. If you hold the key in the unlock position for about 4 seconds it will unlock ALL the doors. If that does not work to unlock all doors, try turning the key two times quickly. One of those two methods works to unlock all the doors from the driver side.
The safety aspect is so that you can choose to open only the driver door with a single turn, or open all the doors when you have passengers with you. If it is you alone, you do not want to unlock all doors because a killer can jump in from one of your other doors into your car. You can choose to unlock ONLY your driver door or unlock all the doors.
From the passenger side, it is a no brainer to open all the doors, because if the passenger is opening the doors, the driver will still need access to the car, so it opens up all the doors from the passenger side.
Old Mar 13, 2012 | 03:28 PM
76 camaro car's Avatar
I think that's the way they were made. My passenger side locks and unlocks all 4 doors with the key, but on the drivers side it just locks and unlocks the drivers door.
Old Mar 13, 2012 | 04:35 PM
Lost Again's Avatar
eny idea
Which is it
Originally Posted by CD5Lover
i have a 94 Honda accord ex 4 door on the passenger side i can key lock and unlock all 4 doors but on the driver side key it only unlock and lock just the driver side door. do some of u 94 accord 4 door do the same or my driver side door actuator messed up?? eny idea
Does the drivers key lock all dors or not?
Old Mar 13, 2012 | 08:31 PM
Originally Posted by Lost Again
Which is it
Did no one read my answer? If you HOLD the key in the turned position for 4 seconds, it will UNLOCK ALL DOORS.
mystikalcaramel
Mar 23, 2019 01:19 PM
romes591
Feb 22, 2008 03:15 PM
JTTeG_X
Audio / Security / Video
Jun 26, 2005 09:44 PM
n3v3tz
Jan 31, 2004 08:28 PM
95sihb
Jan 3, 2003 08:27 PM
