Fluid leak where tranny meets block
Old Mar 12, 2012 | 06:45 PM
SleeperGSR-T's Avatar
Default Fluid leak where tranny meets block
b18c gsr motor/tranny
At first thought I figured it was my rear main seal. When my buddy took a look he pointed out that it looks much too clean to be motor oil.
I suppose it could be tranny fluid but shouldnt this be dark as well?
My clutch fluid leaks from the resovoir(sp?) feed line but I guess the slave cylinder could be going too. I noticed a while ago the nut/bolt thingwhere the line meets the csc was quite loose and at the time of writing this I just realized it may only be hand tight.
From what I understand, and I could be wrong, clutch fluid leaks directly from the csc if the csc is bad, could it be leaking onto the clutch assembly and thrown about the bell housing? My clutch engages quite well and It chirps 3rd as long as theres fluid in it.
To sum it up, there is what I suspect to be clutch fluid leaking slowly from where my tranny meets the block. What might it be?
Old Mar 13, 2012 | 05:45 AM
jdmgsr98's Avatar
Default Re: Fluid leak where tranny meets block
tranny fluid smells and is light pink in color if u used offical acura trans fluid.... mine looks like theres a tiny leak there too but mine is my cam seal leaks a tiny oil when i hit vtec hard
Old Mar 13, 2012 | 07:05 PM
just finished both vtec gaskets and cam seal 1k miles ago. My leak is a very clean looking fluid
Old Mar 14, 2012 | 08:04 AM
jdmgsr98's Avatar
hopfully not antifreeze?... cuz trans fluid is def a pinkish color unless someone used the wrong ****
Old Mar 14, 2012 | 09:50 AM
TheRealTegger's Avatar
Use your nose and your fingers: What does it smell, like? What does it feel like?
Now go smell the clutch fluid, the power steering fluid, your bottle of MTF, the engine oil, the coolant, the brake fluid, and any other fluids you can get your nose on. If you don't have any MTF available, the OE stuff smells sulphury.
Does your drip match any of them?
Is it maybe...plain water?
Old Mar 14, 2012 | 10:28 AM
ah ok ill try that. Ill post back this afternoon with wat I find
Old Mar 14, 2012 | 05:22 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
please do because im experiencing the same thing and i cant figure it out
Old Mar 15, 2012 | 12:17 PM
Welp, I found that the radiator hose just above that area had a small leak but the fluid I was seeing isnt green.
It smells similar to clutch fluid and is actually a light yellow.
It almost looks like oil now but I think its from sitting on the outside of the engine collecting dust, as it is still not nearly as dark.
Im probably going to change my csc and cmc but I might as well save up for a new clutch at the same time.
as stated before my clutch performs quite well assuming theres fluid in the line
Old Mar 15, 2012 | 02:37 PM
The clutch system uses brake fluid. This does not feel like oil when you rub your fingertips together with some pressure.
Pull the boot back on the slave cylinder and see if it's wet under there. If fluid is dripping sufficient to make a droplet on the bellhousing, then the outside of the rubber boot should be wet somewhere.
Old Mar 15, 2012 | 02:38 PM
Why don't you use your own nose and fingers? Your leak may be different from the OP's.
Old Mar 19, 2012 | 03:28 AM
Wow just wow! I have been searching for the source some time my friend
Anyways, it looks like brake fluid but I can't find where it's coming from. It's the motor nor the transmission or coolant. I just need to use a bright *** flood light to see where it's coming from exactly.
It's tough trying to find this leak exactly
Old Mar 19, 2012 | 04:33 AM
Old Mar 19, 2012 | 05:39 AM
It's not there mayne
It's in the back
I'll have to inspect when i get home
fanta!
12
Dec 30, 2005 06:59 AM
mikester_91
Jan 27, 2005 08:44 AM
SiRkid
Oct 20, 2004 08:59 PM
H22Chameleonaccord
Dec 30, 2002 10:59 AM
