MAX REV DP w/inline pro mani????????????
Old Oct 10, 2002 | 03:05 PM
SiRkid's Avatar
Default MAX REV DP w/inline pro mani????????????
DOES it work????????????????
I know rev hard works BUT ive got a 4 bolt flange and it would be easier to go with max rev(plus its stainless) instead of swapping flanges on the rev hard ...the max rev is a shorter mani so i assume the dp will be shorter too... hmmmm...
Old Oct 10, 2002 | 03:18 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: MAX REV DP w/inline pro mani???????????? (SiRkid)
I doubt it.
Old Oct 10, 2002 | 03:32 PM
brian b's Avatar
New User
I'm using a max-rev downpipe, it had to be modified to be like the rev-hard manifold to work with the inline pro..
Old Oct 10, 2002 | 03:35 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: MAX REV DP w/inline pro mani???????????? (brian b)
Notice the word "modified" was used, while the rev-hard bolts right on with no modifications.
Old Oct 10, 2002 | 03:58 PM
brian b's Avatar
New User
Default Re: MAX REV DP w/inline pro mani???????????? (Arturbo)
yeah, i modified the downpipe when i switched from a maxrev to a rev-hard manifold that cracked on me (i should have stuck w/ maxrev, it would have saved me hours of work) but now ive got an inline pro since its a direct replacement (cept it moves the wastegate to a better spot) i believe the inline pro manifold is going to flow more then both of the others, with my new built block and ported head im gonna need it
Old Oct 10, 2002 | 08:17 PM
SiRkid's Avatar
i know but im stuck here.i NEED a 4 bolt flange and rev hard doesnt come with one..so its either buy a new flange and change it OR buy a max rev dp(which is actually slightly better material) and lengthen it..
what to do?
[Modified by SiRkid, 5:19 AM 10/11/2002]
Old Oct 10, 2002 | 08:20 PM
Arturbo's Avatar
Better than steak
25 Year Member
what to do?
In your case I would modify the max rev down pipe.
Old Oct 10, 2002 | 08:22 PM
SiRkid's Avatar
hmmm....
guys who had to modify it..what do I have to do???? any help is appreciated
Old Oct 11, 2002 | 11:11 AM
SiRkid's Avatar
ttt
notsoboosted nemore
Dec 4, 2003 01:05 PM
Civicdrgrcr
Apr 2, 2003 06:12 PM
zojirushi
Feb 9, 2003 06:32 PM
SiRkid
Dec 4, 2002 04:08 PM
lude98
Dec 23, 2001 05:46 PM
