Stock eg d15b7 bogging until 3000 rpm
Old Mar 12, 2012 | 05:06 PM
yo bj's Avatar
Default Stock eg d15b7 bogging until 3000 rpm
I got a stock eg d15b7 and the car is bogging and backfiring under 3k. Also it only happens when the car is warmed up and has under a quarter tank of gas. Checked a bunch of stuff including timing. Maybe fuel pump or filter? After 3k it just goes like nothing was wrong..
Old Mar 12, 2012 | 05:28 PM
lazlong's Avatar
Default Re: Car bogging until 3000 rpm
I'd change the fuel filter. It's cheap and easy to change being right on the firewall. I'd then check fuel pressure and the injectors. Are you getting any codes?
Old Mar 12, 2012 | 06:07 PM
yo bj's Avatar
Just o2
Old Mar 12, 2012 | 06:28 PM
slatermvp's Avatar
try running seafoam to clean everything up and see if it helps. I did that on an old camry I had and it helped. Just a thought for ya to try.
Old Mar 12, 2012 | 06:57 PM
Former User's Avatar
Default Re: Stock eg d15b7 bogging until 3000 rpm
Why are you ignoring a CEL code? Fix the O2 sensor code and check the mechanical and ignition timings.
Old Mar 12, 2012 | 08:45 PM
yo bj's Avatar
We used an ecu with o2 sensor disabled and still did it
Old Mar 12, 2012 | 08:47 PM
Then:
Originally Posted by RonJ@HT
...check the mechanical and ignition timings.
Old Mar 13, 2012 | 12:38 PM
yo bj's Avatar
Timing already checked....
Old Mar 13, 2012 | 12:42 PM
What did you find? Give details.
Old Mar 13, 2012 | 12:58 PM
yo bj's Avatar
Its been just right. I havent checked spark plugs wires everything but the fuel filter and pump
Old Mar 13, 2012 | 01:07 PM
JDM_teh_WIN!!'s Avatar
How did you check the timing? What did you do to check it?
Old Mar 13, 2012 | 02:07 PM
yo bj's Avatar
Timing marks timing light
Old Mar 13, 2012 | 02:14 PM
To set it properly you need to let the car warm up to operation temp. Jump the service connector and then adjust the timing. The car runs in closed loop till it warms up and will adjust timing for cold start/idle. After it warms up it goes into open loop where it looks for input from the various sensors to adjust timing.
Old Apr 18, 2012 | 12:22 AM
yo bj's Avatar
Oh i forgot about this. I fixed the problem the rotor screw in the dizzy fell off now it run perfect!!
Old Apr 18, 2012 | 12:42 AM
dsnONE's Avatar
funny, my brother in law just bought a 4door with the same exact issue, gonna go look @ it for him tomorrow.. perfect timing to see this post!
Old Apr 18, 2012 | 06:22 AM
buskirkzz's Avatar
That rotor screw is the worst thing Honda ever invented. At least yours came out. Mine stripped and took like an hour and a half to remove...
DumaDA
Feb 13, 2017 08:48 AM
EFb18b
Aug 2, 2015 04:28 PM
flipldls
29
Jul 12, 2010 06:05 PM
MidwestSi
Jun 23, 2005 05:43 AM
DualCamEK
10
Dec 25, 2004 08:01 AM
