rear disc brake conversion question..
I saw a thread on an ek rear disc swap, but i couldn't get one question answered. I'm Doin' it to my 96 dx hatch, I know it seems redundant for me to ask since since there's already a thread on this, but i need to be sure. If i use integra trailing arms, i know i need integra rear brake lines, but do the MC, Prop valve, and e-brake lines have to be integra too? or do the 99 Si MC, prop valve, and e-brake lines work with the integra trailing arm and brake set-up? Any help would be most definitely appreciated by a fellow EK lover.
I'm changing the back brakes from drums to discs. I KNOW i at least had to change prop valves cause drum brakes have use a higher pressure rate than disc and leaving the old one in could cause the calipers on the discs to not fully let go. But do I need to change the MC too? I don't think I do... And will the Si prop valve work with my tegi trailing arms/brake lines etc....??? And i was pretty sure about the e-brake cables..
Cool, so it looks like im gunna use the integra trailing arms assemblies with integra rear brake lines, and si e-brake cables, si MC, and si prop valve.. any body see any problems with that? otherwise I'm set
I'm gettin set to start workin' as soon as i get the Prop valve and MC. Probably gunna make a thread for my build.
Did you even read my posts? YOU DON'T EVEN HAVE TO TOUCH THE MC OTHER TO ADD FUILD!!
I'm gettin set to start workin' as soon as i get the Prop valve and MC. Probably gunna make a thread for my build.46210-S04-952 VALVE ASSY., PROPORTIONING 1998 INTEGRA RS
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC CX Hatch
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Hatch
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Coupe
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC HX Coupe
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC SI Coupe
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Sedan
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC DX-V Sedan
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC LX Sedan
46210-S04-922 VALVE ASSY., PROPORTIONING 2000 CIVIC GX Sedan
46210-S04-962 VALVE ASSY., PROPORTIONING 2000 CIVIC EX Coupe
Notice the part numbers I bolded.
You DO NOT have to change either! The only reason to change the MC is when you are adding larger front brakes!
going off your name you have a EJ6
https://honda-tech.com/forums/showth...=641639&page=4
And yes, I do have an EJ6. It came stock with drum brakes..
Yes, I did read what you wrote. But from what I've read in other threads, you have to change at least the proportioning valve because the one from the DX has a higher pressure for the back brakes to accommodate the drums. I've heard that if you don't change the Prop valve and MC that the pressure will be too high and the rear discs won't fully open. Is that not true? I read it in this article:
look at the part number for the SI, and then the number for the DX.
They are only listed for 2000, but they are the same for 96-00
You will see no gain if you swap the prop valves. I am speaking from personal experience when I say this.
I know the part number is the same, that, and many other articles said the part numbers are all the same, but they still have different pressures and the ones in the SI's and EX's are the only ones that don't have to be changed. But according to you, I should be able to hook up my tegi trailing arms, with the tegi rear brake lines and SI e-brake cables, and call it a done deal? I guess if it doesn't work I know what to change lol Thanks, this may have made my life much easier.. And i didn't think I'd gain anything, just wanted to avoid having my brakes locked and having to do it later lol
Yes, that is all you need. I've done it a few cars, aswell as quite a few of my friends.
Use 99-00 SI E-brake lines, generally you want to use the brake line for the caliper you have.
The guy in the article even said hes gotten away with not doing it in some of his friends civics which makes me think its just discrepancies in the prop valves form car to car and just needs to be checked after the swap....
No. based on the part numbers the EX is not the same. The EX/SI share the same MC, and front brakes. But, we did use the orginal prop valve in my buddies EX with no issues.
Use 99-00 SI E-brake lines, generally you want to use the brake line for the caliper you have. But, I am belive the SI lines will work as well.
A lot of the time someone will say you need to swap it, beucase it's what they read. Not experienced.
I know how it is, trust me. I do the same thing before I do something. I am actually getting ready to either so SI brakes, or ITR's in my car. lol
Cool!! Thanks Guys!! I got the Trailing arms today and they're in great shape!! I can't wait to put'em in
I'm Itchin' to get at it. Now that I don't need the MC or Prop Valve I can start sooner. Even though the guy gave me MC and Prop valve with it lol. Got it all for $100!!!
On my LX I had not changed it before doing the brake swap, and my brakes kept sticking. Once I changed the prop valve everything worked. I also read about the different pressures and people running into the issue with the rears sticking. So I went with the SI one and I'm happy. This was just my experience though.
Yea I planned on that. Also gunna grease the **** outta everything lol
Thanks man, if i end up needing it i have a new one so I'm good. Gunna swap'em and see if the old one works lol
