FS: LS VTEC Complete Swap Cheap
Hello HT,
Up for sale is my LS Vtec Swap
B16 Head off of a 2000 SI
B18b1 Block
B16 Trans VIN attached
Type R Cams
Type R Intake Manifold
ARP Rod Bolts/ head bolts
Axles
Shift Linkages
Stock B16 Exhaust Manifold
Motor Mounts
Type R VC
Motor is still in car so i will be provided a video of it running/idling for everyone to see. The motor is located in York, PA. You will get everything to do the swap minus the distributor and wiring harness. Im asking 1700. It is a really solid swap runs great, no leaks and does not smoke.
Will Part out if the price is right
B18b1 Block
Type R Cams
Axles
Shift Linkages
Motor Mounts
Type R VC
